It should overclock similar to the Brisbane (same production process). Probably 3 GHz on air if you are lucky.Quote:
Maybe better though, by then they should be able to have gotten 65nm more refined. Kind of like the switch from 130 to 90, originally the overclocks weren't as good as 130nm but we can hit 3GHz give or take with 90nm. Once 65nm is more refined I don't see why we shouldn't be able to see 3.2-3.4GHz range overclocks. Maybe not right away though. But really, no one knows yet, we'll just have to wait and find out.Quote:
Originally Posted by Scimitar
umm besides 65nm the two are anything but equalQuote:
"Simulations conducted in AMD laboratories indicate that certain database applications will see performance improvements up to 70 percent and certain floating point applications will experience performance gains of up to 40 percent over platforms powered by current dual-core AMD Opteron processors."
This is almost certainly based on data presented by AMD several months ago at their "Virtual IT Experience." At InvestorVillage, they have screenshots (linked below).
"Certain database applications will see performance improvements up to 70 percent"
The Virtual IT Experience shows gains of 70% for OLTP. They do not specify what benchmark they used, but it has been widely speculated (and assumed?) that this is TPC. This is probably the source for the rumors (e.g. in this RWT article) that AMD claims a 10-15% TPC-C advantage with Barcelona.
"Certain floating point applications will experience performance gains of up to 40 percent"
In the Virtual IT Experience AMD predicted gains of 40% for specfp_rate2000. This is almost certainly where this number comes from.
What this tells us
The thing that interests me about both of these slides is that they suggest 10-15% better OLTP performance and ~30% (Some say 40%) better specfp_rate performance than a Xeon 5355. That's a 2.66 GHz Clovertown. There has been a lot of speculation that Intel will release a 3 GHz Clovertown this year, although to my knowledge Intel has never stated this. If they do, and we assume perfect scaling, the 3GHz Clovertown would be about 13% faster than the 2.66 GHz Clovertown. That would make it about the same as Barcelona in AMD's OLTP benchmark, and still significantly behind in specfp_rate.
What this does not tell us
AMD does not say what OLTP benchmark they used. It's been speculated that it's TPC, but then why wouldn't AMD just say TPC?
AMD also does not tell us the clockspeed of the Barcelona processor used for comparison. At this point, it's probably safe to assume that the Barcelona is the highest clock they plan on releasing in "mid-2007." We also don't know how the rest of the simulated platforms were set up.
These are quad-core server benchmarks, most likely selected to highlight Barcelona's strength. We don't know how Rev. H should do in other environments, although the rumor on these forums is ~10% faster than C2D per clock.
all i did was take a quote out of a page that you linked too , i did not start any rumors , what i linked to was in black and white , i have not seen anything else in black and white that proves that the info is false , or a rumorQuote:
Originally Posted by brentpresley
SO did they demonstrate it??
well 3GHz of this vs 3GHz of kentsfield.. i like to see that
as with 680i board u cant really fsb OC higher than 3GHz with kentsfield Q6600 or Q6400
unless nvidia some how find a fix for that
Yes AMD demonstrated it. They demonstrated it saving power while running task manager! :rolleyes:
Hey, someone had to say it! :D
or they saved more power by not running it at all :):banana:Quote:
Originally Posted by freeloader
umm i was talking about performance vs Xeon 5300s ... lol
It has been discussed by your beloved Scientia that the 40% is multiple of 4 cores. That the performance of Barcelona will not 40% or even close to 40%....... What say you to that?Quote:
Originally Posted by The Ghost
God forbid you say Scientia is wrong.
I disagree.Quote:
Both are on 'same' production process, but Brisbane Revision G1 is using OLD transistor design (done for 90nm) which is severely slowing it down and incrasing power consumption. Barcelona is using new transistor design, more metal layers and every process addition AMD mastered in Dresden factory.
Best example is to look at voltage both cores are running on (for Brisbane it is 1.25V-1.35V@1.9GHz-2.6GHz):
http://www.xtremesystems.org/forums/...&postcount=541Quote:
A 65nm silicon-on-insulator process is used for producing the near-450-million transistor device, with dual stress liners and a silicon germanium process is used to speed up the pFETs. Eleven layers of copper and low-k dielectrics connect the device.
At 95 degrees Celsius, modelling suggests the processor will run at between 2.2 and 2.8GHz at 1.15 volts. Each of the four cores include eight temperature sensors. The on-chip northbridge contains a further six.
I will expect better overclocks from K10, especially dual core variants ;)
PS. Off topic THIS IS MY 500 POST ON XTREMESYSTEMS!!
Rumors: the production process used for Barcelona is a little different from the one used for Brisbane. So, maybe a better OC-er, maybe worse or maybe same.
TPC-C and SPEC_FP are bandwidth and FPU dependent benchmarks and are not representing the real world. Especially SPEC_FP is not adequate benchmark to conclude how Barcelona will perform in server environment. Servers use software which depends mostly of the ALU performance. IMO K8L AL performance will be 10% faster clock for clock than K8, but slower than Core2.
As you said it gojdo,it's your opinion and since you saw none of the tests and benchmarks of the K10,it's worth zero.Quote:
Originally Posted by gOJDO
True. This phoney war has lasted too long, it will be a blessed relief to see the first benches and know for sure.Quote:
Regards
Andy
if you have something to say to Scientia , by all means go to his blog and post itQuote:
Originally Posted by n91htmare
but nothing that any one has to say positive about amd would be OK with you
all we have is what amd has said for sure , anything else is not a proven fact
funny when intel said said how good it was going to do with the conroe , , what did iontel say it was going to be 40% better ? 80% better? but then agan intel was talking about better then it's own cpu
didn't intel say the same thing about conroe , before it demonstrated conroe ?Quote:
how long before conroe was demonstrated was the numbers coming out on how good conroe was suppose to be ?
there was no flamebaiting in my post , but any one sho posts anything good about amd to you , is flame baiting
well, regardless of how they perform against one another... both AMD 65nm and 90nm are proven not to overclock nearly as well as intel 65nm.
So, for the enthusiasts (like us) it should be an interesting war. Intel must be nervous though if they want to get 45nm out the door 6 months early.
you are comparing a 12 stage to a 14 stage processor on the field of max clock speed, while ignoring the fact that Intel has 6 months advantage in the 65nm Process.Quote:
Originally Posted by irev210
Nice comparison.
Werd™
I defiantly cant wait until Intel is back down on their knees.
Everything that Intel and I have been through, Im REALLY glad to see Intel the low dog.
~Mike
AMD has SiGe and DSL-SOI-3 :stick: and the new 65nm transistors, they will allow less power leakage. Brisbane use 90nm transistors :slapass:Quote:
Originally Posted by nn_step
I expect that Barcelona will overclock at 3.5ghz on air, like kentsfield. :toast:.
Shangaih may do it at 4ghz. :slobber:. Shangaih is on classic AMD's 45nm, but the next one will use imersion 45nm and High K :eek:. AMD is gonna clock very high :clap:
AMD said that +40% on clovertown benchs are not rare. ;)
I can't wait 4 see a sandra benchmark of the Barcelona's FX :slobber:
I'm just wondering me if the FX will use HT3 or old hypertransport :confused:. It Would great If AMD Get out a RD790+ bord E-ATX for the FXs with separate powerplanes.
Barcelona can do separate power planes, but actual motherboards F/AM2 can't. F+/AM2+ can ;)
what part of current Barcelona chips are about 3 months old and are missing a feature or two of the ones that you listed. You have to remember AMD always puts yields ahead of minor advantages. And the difference between AMD and Intel is that AMD is a Design company and Intel thinks of itself as a Manufacturing companyQuote:
Originally Posted by madcho
Shouldn't a smaller process have MORE leakage...Quote:
That's why people are adding new features to the materials, like SOI, stranded silicon, high k dielectrics, etc, to offset some of the leakage problems.Quote:
Originally Posted by aznblueeboi
it largely depends on many factors, however just a dumb shrink would cause about double the leakage (for 90nm to 65nm)Quote:
