Nice rams:toast:
Nice rams:toast:
commando is supposed to be a tad faster it would be interesting to see your 32M for sure :DQuote:
Originally Posted by corvus_corax
sure, same speed.Quote:
Originally Posted by dinos22
to corvus_corax:
1200 443x pi_1m is easy, but 32m tooooooooooooo hard.
They should be D9GKX, at least the ones in my stock are D9GKX. I have some DDR2 1200 CL5 and DDR2 1066 CL4 in stock and I'll allocate some to tankguys in US and NCIX in Canada for NA market.Quote:
Originally Posted by over@locker886
I shipped 1 kit of DDR2 1200 and DDR2 1066 to OPB so he should have some nice pictures and results before end of this week.
heat spreader and memory kits shipped seperately, customer have an option to install it on their own or not. This is how it looks like with HS on.
I will have Taiwan ship more if these two high-end modules sells well. Let me know if any of you have questions. :)
common Victor let's see the 12m 5xs time :DQuote:
Originally Posted by VictorWang
use a dedicated Hard Drive controller
very nice clocks theer.. :)
Victor YGPM :)
It was not easy :D But here 8M and 32M 4-4-3Quote:
http://smg.photobucket.com/albums/v6...200443sp8m.png
http://smg.photobucket.com/albums/v6...00443sp32m.png
(Steps: 0 5 11 21 done
Sadly, pi times suck. I was playing a bit with 3D and the system ended really corrupt after that :D , so i guess that's one reason :(. Anyway, i hope to get better times soon ;) .
Edit: A little update :D the same crappy OS but after restore
http://www.xtremesystems.org/forums/...&postcount=460
LOL how come the time is THAT bad lol
Probably the bench mas made from an actually destroyed OS after a hard benching :fact:Quote:
maybe a asus commando can do it ;)Quote:
If 13m03 is without tweak then Largesystemcache=1 + copy-waza must get you sub 13m easy. I recently tested them and they improved time by around 20s at that speed :)
most likely those tweaks are already implemented hehQuote:
Originally Posted by kiwi
Then what does 'not any tweak' mean? :D Are there any other super tweaks (memory subtimings not counted)?
Heh, a Team rep said it should be GKX while Victor's sticks are high-binned GMH. I suppose GMH still scale better with volts then.
Team sell 512MB sticks as well, not sure how they OC compared to 1GB sticks.
Maybe an Infinity 965 will make sub 13m a piece of cake, its NB latencies are much tighter vs P5B Dx. Let's hope its dividers aren't borked either :D
That's a nice memory kit you've got there Victor :toast: I think sub-13mins is possible at these clocks with 2*1024Mb.
With 2*512Mb, I can get 13mins 03s and 13mins 02s as well with tRTP = 4.
http://img267.imageshack.us/img267/3...m03968slo9.png
so close Before :D
have you tried 4:5 ratio with clockgened 450MHz FSB *8 :)
It doesn't work... :)
450*8 @ 4:5 works on the quad GT :) 1066 strap also...Quote:
now we just need someone to break the magic 13m mark :cool:Quote:
Originally Posted by fhpchris
Sorry for this noob question but could you elaborate on this tweak or provide a link? Much thanks. :)Quote:
I think that Bachus has already break the 13m barrier @ 3.6GHz....:)Quote:
If I correctly remember he was @3.62GHz ;)
I'm waiting for some D9 2Gb Wintec memory kits; may be I'll be able to do it... I don't know what the difference is between 2*512 and 2*1024 in term of computation time for Spi 32M. I've never had the chance of using very good 2*1024 kits.
nah matey none of us have YET :) but it's clearly within reach as Victor said he didn't tweak much with that run so i'm sure he can do itQuote:
Originally Posted by hipro5
Before is limited but 1GB kit otherwise i would pretty much guarantee you we would see that from him for sure :)
do some searching here as these are the two most commonly used tweaks for SPI :toast:Quote:
Originally Posted by lopri
wow, It's awesome !!!
