nice m8 :)
any particular reason for the half multi?
nice m8 :)
10.5 was max I could choose. :p: and 10x kept giving me blue screens.Quote:
Originally Posted by SOLDNER-MOFO64
I hope to get dual channel ram next week or so for the rig.
Good work alucasa :toast:
Nice CPU you got there :) After all this OCing try to go down to 1.0V and find max stable frequency ;)
:clap: :clap:
Is that much Vcore absolutely necessary? You may be better off with a 90nm CPU then :p:
http://img329.imageshack.us/img329/8521/cpu3111jz1.jpg
Yes, I am probably better off 90nm or even 130nm.Quote:
Originally Posted by s7e9h3n
Or - even 1 µm?
Maybe you should get a socket939 then :DQuote:
http://img76.imageshack.us/img76/129...128vfj8.th.jpg
http://img485.imageshack.us/img485/5...264vum2.th.jpg
Did lowering the HTT and ram mhz have any positive impact on the OC?
Does it really need that much voltage to get a stable 2.88ghz? I thought the 65nm chips can hit 3ghz on relatively low voltage. But anyways, nice work.Quote:
Originally Posted by alucasa
I didn't need to. For some reason, I upped vcore too much. 1.4vcore was probably more than enough.Quote:
Originally Posted by awdrifter
One thing I noticed with my 3600 Brisbane is its ability to handle voltage. Seems to scale much better with the volts than Windsor does. My 3800 Windsor will do 2.8ghz with 1.5v but nothing more, and going to 1.5v over stock only netted me roughly 75 to 100 mhz.
But Brisbane scales pretty well. Up the volts and up your clock.
Also Alucasa you're right about Brisbane running cool. Even when I was torturing it at 1.675v it ran much cooler than my Windsor...
Ply
http://www.ripping.org/database.php?cpuid=543 ;)Quote:
