just what I needed. Thanks!
Thank you Vrykyl ;) ;)
can you pls post a link to download coolbits?
thx
ask and you shall get :D
http://downloads.guru3d.com/download.php?det=815
Originally Posted by Vrykyl
thx you ;)
Please help: How to have separate 2D & 3D overclock with 8800???
atitool. get it at guru3d.
As I said in my thread:Quote:
Originally Posted by crazyea
Originally Posted by PIRATA!
This damn RAM frequency does what it wants with all program!!!
Is it maybe some NVidia drivers issue??
are you running vista? Im not sure you can oc in vista as of yet.
I have WInXP SP2 now, but I will soon install WIn Vista Ultimate.Quote:
Don't know yet if 32bit or 64bit version.
But what do you mean that on Win Vista is not able to overclock??
Do you mean only overclock or all clock changing, like underclocking??
...So I take it that Rivatuner doesn't work in Vista? I want my new baby to sweat. The stock cooling should do the job as I find it amazingly good, and that's coming from an old smug SPCR-boy. I canceled my order on the new Hr-03+ as it shouldn't be needed.
its seems that nothing works in vista yet, nvidia needs to be on top of this
atitool 0,27 beta works!
I did this and installed coolbits. I then removed nTune. Now when I went to set my global settings the max AA is 4x? What happened? I can run alot higher in some games, and want to. Am I just stuck?
Thank you ViperJohn !
