EVA2000 tested 4 dimms of 6400PHU2-2GBHZ (4-4-4-12 ) dimms succesfully with a FSB of 400 and ram even at 900Mhz....
i just don't recommend 680 or 650 to run 4 DIMM. We got many feed back that users can't run 4dimm. i ask Asus and Dfi and they told me that some of the C55 chip might not strong enough to run 4 dimm....
Well I had my PC6400GBHZ coupled with o** 8500 at 800mhz 4-4-4-12 2T at 2 volts worked fb till 333Mhz FSB then it went wrong...but they worked well together at 4 gig , but windows XP couldn't adress it all...
Hello GS
Could you confirm compatibility of the F2-6400PHU1-1GBZX modules on a P5N32 SLI plus (650) board. The memory is EOL and "for Intel platform Only". I just need to check otherwise I need to buy other memory for my new mobo. Any recommendations on best 800mhz (2GB) g.skill modules for this board?
Zardew
Dammit I have the 6400NQ ram but can't get to vista... hate it.
Updated to latest bios 1302 and applied all the recommended settings... blue screen on loading :(
P5n32-e sli it is... what should I do what should I do..
simon plz fill in this template with ya settings plz... you running 4 dimms ? win 32bit ?....
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: (means FSB)
Actual FSB (QDR), Mhz:
MEM (DDR), Mhz: (means mhz speeds)
Actual MEM (DDR), Mhz:
Vcore Voltage:
Memory Voltage:
1.2v HT Voltage:
NB Core Voltage:
SB Core Voltage:
CPU VTT Voltage:
DDRII Controller Ref Voltage:
DDRII Channel A Ref Voltage:
DDRII Channel B Ref Voltage:
tCL (CAS Latency):
tRCD:
tRP:
tRAS:
Command Per Clock (CMD): 2 clock (2T)
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
tRD: AUTO
tRFC: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
well thanks for offering help but I'm afraid it isn't needed anymore... went to local hardware shop and bought a 2gb of another manufacturer... works now
thanks anyway :)
DDR2 1000 / F2-8000
ZX Series
FSB SPEED 1066
DDR2 SPEED 1000
VOLTAGE 2.3v
TCL 5
TRCD 5
TRP 5
TRAS 15
CMS 1T / 2T 2T
TRRD 2
TRC 5
TWR 3
TWTR 6
TREF 1
TRD 3
TRFC 27
ASY LAT 2
I assume this is what I should use for this RAM:
F2 - 8000 CL5D - 4GBPQ
DDR2-1000 PC2-8000
2048 x 2
CL5-5-5-15
Correct?
not all as these are 2gb dimms and not the 1gig versions as you quoted...and these put also more strain on the NB chipset...
Timings are correct but plz do not set voltage above 2.1 volts, I let the rest be autodetected and don't put it manually, I just put TRFC to 42
