After a flash if you don't fully post, try only one stick of ram until you rasie your Vdim and re set and post cleanly and then replace the ram. Also bios 1004 and probably 910 need a extra notch of vcore to hit the same actual that earlier bioses did. Once I did all these things, 1004 is as stable if not more so, than anything that came before. main thing is more vcore. After that you can overclock quite nicely.
