Almost have it installed just checking some things.
Hang in there guys I have the thermalright backing plate and I drilled the holes to match the studs from the fuzion. It should work. The thermalright plate is solid steel. I just got to check the resister around the cpu area underneath the board to see if they will be smashed by this back plate but it looks good so far. Ill post pics and results tommorrow. If my theory is right I think I will get not only a safer install using the thermalright plate but also better contact with the convex shaped block so better temps will follow. By the way the proper drill bit size is 9/64 inch.
yahoo! backplate mod is a success
http://www.xtremesystems.org/forums/...=1#post1972879
I wish we knew before I installed
I wish the guys that knew about this mod would have posted before I installed my waterblock its a major pain to pulll the motherboard out twice I have to drain all the water out.
