Make sure to check out this mod it does help make the mounting more steady and a little more consistent.
http://www.xtremesystems.org/forums/...=1#post1972879
I wouldnt worry about it... swiftech uses IIRC 45lbs of total mount pressure. Every singe stock Intel HSF warps the crap out of the board. Anyway, just don't use too much force to mount... mount it like you do all other blocks.Quote:
Originally Posted by h20 frag-monger
Kindly spell Shamino's name right. Its not Shimano, as in the bicycle components heh
Shimano hehe my bicycle has that stuff written all over it... BTW my stock hsf does evil stuff to the board. I had to push with all my strength to get the pins down:PQuote:
Originally Posted by IanY
to add my results of the Fuzion:
Storm Rev1 using CoreTemp
Idle 41-42C Load 54C max
Fuzion :
39-40C Idle 51C Load
I used Orthos Large FFT's to compare. This is also comparing a fresh application of AS5 on the freshly mounted Fuzion vs the Storm's performace on a fully cured AS5 application.
In response to someone earlier in this thread, the reason no one talks about the MP-05 anymore is that it's no longer in production. It's discontinued and has been completely replaced by the FuZion.
Originally Posted by Methylphenidate
They are not even made by the same company. Are you sure the Mp-05 is discontinued, I still see them on the cooltechnica site?
D-tek was the primary producer of the MP-05. I've spoken with Danny personally about MP-05 availability. He is sure no one is still producing them.
MY mistake then, only ever saw the Mp-05 sold through Cooltechnica as their own.
Yeah, my understanding of it is that that's what made their partnership degrade so quickly. That's why availability of the block was always poor even though it was a great performer.
Done! :toast:Quote:
I've added your results to the summary. Thanks!Quote:
Originally Posted by Budwise
I did not test in the ways mentioned here, maybe I will if I get the time, but for me Fuzion bested the apogee and storm on my Kent, but the storm bested the apogees on conroes. I have not tried the fuzion on my conroes.
Update: Added coolingmasters excellent review of the Apogee GT here...
http://translate.google.com/translat...language_tools
Too bad they didn't include the Fuzion in their testing.
Please fill in my blanks:
Philly_Boy (Apogee GT vs Fuzion)
CPU: E6300 OC to 3.7GHz @ 1.6 Vcore
WC Gear: MCP-355, PA120.3
Test SW: TAT
DT Results (from CoreTemp): Fuzion 37c; Apogee GT 34c Delta T from ambient air
Winner: Apogee GT (flat/bow?) beats Fuzion by 3
Link: http://www.xtremesystems.org/forums/...7&postcount=54
NP, but while I'm at it... Did you use the flat or the bowed base on the GT?Quote:
Originally Posted by Philly_Boy
One other thing, while we're at it... can you clarify if the results from the first CES test were using the flat GT base? The second test (the next day?) was using the bowed base? Is that correct? Thanks!
A couple of issues I would like to raise
Measuring relative performance of these blocks on the same rig, whatever its configuration, is entirely valid since you are comparing like with like - however the delta T figures being used ( core temp to ambient ) are meaningless as they are completely dependent on the performance of the whole cooling loop. The only valid comparison would be the delta T between core temp and water temp at a given flow rate but since each tester is using a different configuration that is not possible. The only useful conclusions that can be drawn are from the relative performance of each block in the tests to see what trends emerge which would seem to be that - on Kentsfield at least - Fuzion and Apogee GT (bowed) about same, better than Apogee and noticeably better than Storm and MP-05.
Sorry if this is a bit of a rant but I hate reading conclusions based on meaningless results. Some of the results listed would require a cooling loop that could take a load of 150w+ and yet have the water remain at ambient!!
Regarding the full load figures I should remind people that Prime95, Orthos etc do not heat up a Kentsfield as much as CPU Burn in and way less than TAT. Difference for me between Orthos & TAT is around 5C!
My rig QX6700(lapped)@3.75(266 x14) @ 1.5v(1.45v actual), 680i cooled with modded DDC ultra, PA120.3, 3 x Noctua 1200rpm fans, Apogee GT (bowed), DD880GTX block, DD680i N/B & Swiftech MCW30 on S/B - in parallel. Can run any bench/test 24/7 in closed case. I also have Storm, Apogee, MP-05 and ApogeeGT outperforms them all. I am waiting on a Fuzion so I can continue testing but I am not expecting any great performance difference from ApogeeGT.
Incidentally regarding the load on motherboard - especially with bowed blocks - I too am more than a little concerned and feel that a backplate would be a good idea. Swiftech? D-Tek?
I used the Apogee GT with the bowed base for my anecdotal test. I corrected my part of Post #1.Quote:
Originally Posted by virtualrain
Swiftech Challenge Night (Tuesday) was with with both flat and bowed bases on the Apogee GT. The results from the next night are now correctly stated in post#1. The Fuzion with it's own mounts and mounting methodology hit a 37.1 Delta T so we accepted that as the final figure for the Fuzion.
Since every test summarized in Post #1 just swaped CPU blocks and kept everything else the same, the delta T figures are not meaningless... as you say they are measuring the relative performance of these blocks on the same rig/loop.Quote:
Originally Posted by lawnmowerman
Thanks!Quote:
It is I who need to say thank you....for gathering and presenting the data in one post so the uninformed can see which block might be better for them.Quote:
I'll have a boat load of data in 10 days when I publish the G80 water block review.
I see C2D's in the list but no AMD's. Could somebody please do a comparison between the Apogee GT, Fuzion, and storm on a dual core AMD with and without the IHS? Thanks :)
Sorry my AMD rig is down at the moment....but maybe we can make that happen. I own all those blocks as well as a few others. I have a FX60/DFI LP Expert/Muskin Redlines based rig that we could dust off and do a comparo on an old skool s939 rig...Quote:
Originally Posted by SparkyJJO
I've got an MP-05 and a 6k2 if you want to borrow them to add them to the testing.Quote:
We'll tawk soon.....gotta clear out some backlogged reviews then this can happen.Quote:
Originally Posted by DragonOrta
