20% done:
http://images.people.overclockers.ru/108809.jpg
http://images.people.overclockers.ru/108808.jpg
http://images.people.overclockers.ru/108807.jpg
Workmanship and all looks the goods look forward to the test results, as some others have eluded to though regarding the flow of water, I see the centre missing the flowing "goodness"
http://www.myfoto.com.au/Photo/snapp...iew/108781.gif
That said I think it will go reasonable well but nothing to write home about... time will tell :-)
The first tests I shall lead on the processor - AMD 3200+@2700MHz 1,6\1,7\1,8V - without the thermal allocator. I shall lead the test on 6600 little bit later
AussieJester You are right, I almost with all agree
The basic author of the water-block has advised to use it in such a mode:
http://images.people.overclockers.ru/109090.gif
How you think it will not be worse than a parallel stream of water?
Would this create some kind of turbulance in the centre of the block as both streams are moving in opposite directions? I don't know if this is a good or bad thing! :rolleyes:
Probably it is necessary to look results of tests of both ways :(
Has made one of these days SLI - system of water cooling, and it was ran under tests:
http://images.people.overclockers.ru/109719.jpg
http://images.people.overclockers.ru/109713.jpg
http://images.people.overclockers.ru/109720.jpg
http://images.people.overclockers.ru/109718.jpg
http://images.people.overclockers.ru/109717.jpg
http://images.people.overclockers.ru/109716.jpg
http://images.people.overclockers.ru/109715.jpg
http://images.people.overclockers.ru/109714.jpg
Delta T (CPU\Woter) = 12C - S&M 15min Test's
Lol, it's a tubing rainbow :D Can't be good that that one tube it twisted and bent @ one barb on the gpu block. I'm 100% sure your aware of that. Also missing clamps @ gpu and cpu block AFAIK. Anyways I look forward to seeing some controlled results with this block.
You gotta love the big glass pickle jar for a Res.. You could get one for free at Costco, just need to eat about 200 pickles. Somebody should put that one up the next time somebody asks what the best reservoir is.
Here photos of the engineering sample of the water-block on a videocard, it is the test version, therefore such "terrible"
http://images.people.overclockers.ru/110834.jpg
http://images.people.overclockers.ru/110835.jpg
http://images.people.overclockers.ru/110836.gif
I like that .gif animation there
Pete
It will be fast the full test and huge video the report on work...
Those looks like really huge barbs. At least from the pic. :rolleyes:Quote:
Originally Posted by Nordling
Amazing Nordling, im in awe.
malccy lol
Very good looking designs. Not sure on how well they will work but the certainly look the part:slobber:
How do you plan on cooling the memory of the G80, looks like the block will 'block' at least two chips.
The given water-block only one of several types, tests on 8800 will be soon, wait... There Will be water-blocks parts covering all 8800... THK
http://images.people.overclockers.ru/111369.jpg
Hi, where can i get this CPU Cooler?
cpu block looks beastly... wonder how it performs..on a quad
i like the look of that gpu block though..
Also wondering about CPU cooling. The only other similar (production) block that comes to mind is the Arctic Web block, but that's designed for cooling a tec, with a more spread-out heat load. And even then, the pin matrix is diagonal, which would help spread the flow out.
