CES: Not at all what happened! We believe we damaged the motherboard with a hardmount (OP thinks he tightened way too much and cracked a trace). Replacing the motherboard next day with exact same model resolved all stability issues.Quote:
Originally Posted by nikhsub1
Sorry I didn't send you the o-ring today, vendor was late in delivering. Parts were received 5 minutes ago... NP to send you another block. Note: if you want to verify whether base is now concave, simply place a straight edge across it, and inspect against bright light.
Mounting system of Apogee GT is same (same posts, same springs) as regular Apogee. Thousands of Apogee sold in 2006. never any pb. Hard mount is never advisable as too risky (ongoing debate about this with OP), unless you have a means of limiting the torque by placing a spacer of the correct size between hold-down plate and motherboard, or using an acorn nut (blind nut) with the correct length screw.
