damm these sticks are nice... also pricewise very attractive!
Anychance anyone has seen a kit of this in the US? I've searched a bit with no luck though? Probably one of the best kits I've seen period! Infact I'm amazed this stuff if running 1000Mhz+ at 1T at 4-4-4-4, blown away!
hi!
after these very good results from you ,here some standard results like cl5 and everest .
had not a lot of time to play,just put in and go results.
the everest result is with clockgen,because my evga relaxes the strap at FSB1700
cpu-z screen is with commando mobo
PS:I`m a big fan of your reviews on ocxtreme EVA2000-thank you
Glad i could help :)
That is tuely insane work there bud....very very well done :)
I notice in the pic you left heat-spreaders off ram? Do you find this helps?
i have bought this KIT!
running now 4:5 divider in P5B Deluxe mobo!
any chance to run in cl4-4-4-12 @ 1000MHz with 2.25V?
should I try?
i wouldn't really trust the software reporting there...........i'm sure it's not that bad..........DMM would show the real figures
Here is what my Cruical value 5300 can do:), 449*8 1:1 1T SPI32M 13 min 36s
http://bandwidth.se/images/1042.jpg
Its async, please try to do this linked and sync?
does running your ram async/unlinked really hurt performance that much?
i now it creates extra latency but is it really that much more than a regular divider (eg. 2:3, 4:5)
sure does
NIce runs at T1, anyone have any idea when this is showing up in the states.?
NICEEEEEEE!:p:
just tryin this KIT, so far 1200MHz @ 2.25V ~ 5-5-5-18
http://forum.hwsw.hu/uploads/post-10-1179380311.png
can anyone tried the crucial 8500 for the highest 1T run?? thanks :)
Why is he able to run 1T when everyone else I see is running 2T. Is there possibility to do 1T on Certain 680i motherboards?
he is ONLY able to run so high as he is async which is NOT as fast as sync and linked. 900 to 980 is seriously fast linked and sync and pushes the chipset really hard...980 to 500 usually will not boot then over 500 relaxes the latency and if the chipset will do it you fly over 510 with ease. Raja did over 500 linked and sync with 9200 Reaper but like me struggled to do 980 and his rig was quite a bit faster even though his cpu was a few mhz lower.
1000 1T is not that hard if you are on a high latency setting internally on the memory controller, this is why I asked to see the same result linked and sync as thats where all the speed is when using i680.
It is not so much that these dimms are incredible, its more where he has the board set up to run them then any thing else
500MHz in CL4 @ 2.3V
http://aycu07.webshots.com/image/163...5222547_fs.jpg
hm, CL4 proved to be instable at 1GHz.
thing is, do we know what chips are on the the A-DATA extrem edition 1066+ moduls? its supposed to be d9gmh...
hm, now its workin fine with 2.30V at 1GHz CL5... this should be better eh?
nyeh, és nálad hogy mennek? fesz? timing? stb..
laragirl83 - 4:5 divider is very bad for stability, try 333FSB and 2:3 divider
