Re: How to volt mod IC7 Vmem
Originally posted by FUGGER
Check the 1K vr and set it to 250 ohms and connect the center pin to the contact pad closest to the winbond chip (doesnt ring as ground with continuity test to ground) and the ground pin you setup vr at 250 ohms to the ground pad or a ground of your choice.
I did this mod last night, I soldered a VR from Pad closest to the Winbond IC to ground, (fan header)
It didn't work.
I had to solder one end of the resistor to the Winbond side Pad and ther other leg of my VR to the other R50 pad.
Can't just solder to the ground of your choice.
OPP
