It's locked. Max is 23x like shown.Quote:
Originally Posted by awdrifter
Here is the pic of it.
http://img150.imageshack.us/img150/9...1056yr5.th.jpg
Hard to do that especially when the rig keeps shutting down due to overheating.
Here is the correct screenshot.
25x max.
http://img314.imageshack.us/img314/9...1057ge9.th.jpg
I have to turn it down and rework cooling now.
[QUOTE=alucasa]Hard to do that especially when the rig keeps shutting down due to overheating.
DUDE!!!What is hot? The chipset/board?
Just wondering what case is that (manufacturer/model#)?
I considered the Quad FX, but with the extreme lack of memory slots, I didn't go ahead with it
Nice looking rig though...;)
CPU01 (The one far away from middle fan) is hitting 90c while CPU00 is at 50c.Quote:
Originally Posted by pplapeu
Cool setup, thanks for sharing. :)
http://www.chenbro.com/corporatesite...s.php?serno=41Quote:
Originally Posted by lutjens
Alright, this setup might work out.
Apparently, Zalman CNPS9700NT AM2 works on socket F cpu retention.
http://img442.imageshack.us/img442/2...1059kt9.th.jpg
Nice, that's a lot of head room for oc'ing.Quote:
Originally Posted by alucasa
The problem is with heat. It is idling at 50c and 60 to 70c at load.
Are you thinking of putting it on water or phase?Quote:
No, the current heat level is fine as long as there is no OC. My S940 opty rig ran fanless in 80c for 2 years without a shut-down. So, 70c is just fine.Quote:
Originally Posted by SkewdLogix
I do need to get another Zalman cooler though. This stock amd heatsink is too loud.
P.S. CPU-Z does not recognize the CPU. It sees it as S1207 opty.
check the CPU voltage
1.424vQuote:
Originally Posted by nn_step
you should be able to get them to run just fine at 1.2v
undervolt them man, it'll save alot of power
now if you check temps they should be a healthy bit lower
http://img409.imageshack.us/img409/9...1062ih2.th.jpg
CPU2 is on Zalman cooler and was the one that was hitting 90c before I mounted the zalman cooler.
It was 50c. Now 45c.
CPU1 is supposed to be the cooler one as it is much closer to middle fan. But meh, only 2c drop with fan running at 6k rpm.
Dropped a little more voltage and it is managing to stay at 65c at full load.
You'll have to drop chipset voltage or improve cooling your chipset to correct that. Just be careful about pushing that too far, it can corrupt things crazy fast
I won't go under 1.2v. It's at 1.22 now.
How sad is this... :/
whats the other option from cpu fan mode ? PWM and ???
Also, what's the default vcore ?
Even my Kentsfield @ 1.45v run cooler with silent fans :stick:
alucasa, so what about overclocking?
