Originally Posted by Lestat
i want you to take a good look at this picture, ignore the numbers in the bar graph just look at the line graph, the red and blue colores.
those are REAL results.
do you notice anything odd ?
not one of those controllers is reaching 300Mb/sec.
and i will guarentee you the Sil 3112 is a better controller than the ICH8r
this is the NVidia 650i sata controller NON raid using a SATA II Maxtor 300gig drive. in Sata II mode
the other is my 2x 36g Raptors in Raid 0 on my NetCell Revolution SR5000 w/ 64megs of ram onboard.
now i will guarentee you that beyond anything else that that Netcell is a better controller than any onboard raid controller out today, its a hardware raid controller PLUS it has 64megs of onboard Cache for the raid caching.
there are NO drivers that are needed to be installed for this controller to work, it is driverless, there are 5 Raid controller rom chipsets 1 for each port, a raid cpu and 64megs of ram. it dont matter what OS you use no drivers needed. and whates even more funy is that no matter waht OS you use you can not even see the controller, all you see is your raid array,. you dont see the controller card at all, technically it doesnt even use an IRQ thats visible in windows.
what do you see ?
now go back and ask yourself is TOm's results realtime or Peak Burst results, or is it just a bunch of horse crap.
