http://www.soleusair.com/compressor/...SG473EA1NC.pdf
That compressor, while listed as R22, is the most similar in capacity to yours that I could see.
Obviously getting the correct datasheets would be best, but an approximate value can normally be used for Rotaries. I don't know if I would recommend that to the 'layman', but it can be done.
100% of all mid to small size rotaries I've used have all been capacitive run compressors.
For the 1/2HP Hitachi rotaries, I use 20uF capacitors.
For the 3/4HP ones, I use 30uF capacitors.
For 1HP, I used both 30 and 35uF capacitors.
Some of the Rotary compressors I've used were old or discontinued, and I could not source a datasheet even from the original manufacturer.
At that point, I researched very similar compressors based on application, LRA, displacement, etc., and found enough information to approximate the correct run cap, and have had no problem with that.
Keep in mind though, that run cap application is more critical than start cap.
If you have too large a start cap, it does not pose the same risk as too large a run cap. A start cap does not run for very long, and in it's worst case normally only kills the compressor.
A run cap can lead to overloading and fires, as stated in previous posts.
I will not recommend a particular run cap for you, but I would recommend reading that PDF, particularly near the end that shows run cap application for this series of compressor. The most suitable and most universal run cap in that list appears to be the 400vac, 30uF cap. That is what I've used primarily on 3/4hp rotaries of this general type with no failures to date.
As stated though, it would be best to wait for a reply from Hitachi for the correct datasheet.
Cheers
Gray
