I read that there is a gap between 1.4v and 1.6v , if u choose 1.625v then 1.625v u getQuote:
I have the gap to...but it sets in at 1.3..anything between 1.3 - 1.6 I get 1.39...seemse to be pretty stable there.
Havenīt tried above 1.6 yet...but will do later.
Do anyone have a working clockgen for this board? I want to boot at 424 and raise the fsb in windows up to 433 so I can get a lower strap, but it seems like the clockgen on cpuid.com isn't working correctly with this board :(
*EDIT* NV I found the Beta *EDIT*
thought u guys might want this for reference
http://img266.imageshack.us/img266/4701/680iyt7.png
Would someone please post some max OCs with the PLUS version? I just bought one and am dying to see if it performs like/better/worse than the non-plus...
For some reason I can't get passed 4GHZ, I don't know the reason but just dosen't work for me with this board. Could be related to some option maybe but I don't know for sure.
I hit 7x515 with a E6300 with it being dual Prime stable, tried for 7x525 and corrupted the CMOS. :( This is with the new 0404 BIOS that corrects a few issues and hopefully will be released shortly.Quote:
Originally Posted by onthepulse
found clockgen beta for i680, but it doesn't seems to work on this mobo, i get BS everytimeQuote:
Originally Posted by NiCKE^
p.s and could you post a pics of your vcore mod, please
Sounds pretty nice. Can't tell you how many times I corrupted the BIOS on my DFI Expert :)Quote:
Originally Posted by bingo13
What cooler are you using?
And, NiCKE^, if I got to 4GHz, I would be happy :thumbsup:
i was looking at the table and saw an Asus Striker (non-extreme)...
Has anyone seen one of these or is this a new board that's going to be released like the P5N32-E+
I am using the Tuniq 120.Quote:
Did you reached this high fsb's with the original chipsetcoolers/heatpipes, or was it with aditional cooling? Because those heatpipes became very hot.Quote:
Have sm1 put 1.625v or more? Does it really wors? or just another myth?
http://pics.pajper.net/p5n32-e.vcore.jpg
50k VR, I think you can also use a 20k.
Post some more OC screenshots please...
My P5N32ESLI+ is arriving next week. I am going with the retail E6400, Thermalright Ultra-120 and my Leadtek 7600GT SLI
Not 100% sure on the RAM though. I am kinda inclined to pick up a cheap set of A-Data DDR2-800 Vitesta and just aim for 450-470FSB at 8X multiplier.
Any suggestions on the RAM? Not sure about buying Micron if the ADATA will do DDR2-900+. What do you guys think?
this board its good for me,in combination with e6600,and 8800gts
i obtained in 2006 10321 points ,with cpu at 3000 and gts at 630/1980.
but its confusion with chipset 650i or 680i?wai plus maybe minus?:confused:
later edit:i discover de sb ,and write 590i not 570i,in cpuz show 570i,complectly wrong.
asus mistake something
thx NiCKE^ , worked like a charm
Air cooling[room temp arround 0°C]mainbord was not modded or anything. config ATM C2D E6600@4312MHz 1.70V, TR Ultra-120, Patriot 2x512MB DDR2 6400@805 5-4-4-15, P5N32-E SLI Plus. I believe that motherboard has potentialQuote:
http://shrani.si/files/u12s8j5.jpg
its 680i 100%,i have a friend with non plus,its same bios,advantage my,not have electrolitic,just tantalum and polymer.
Awesome results. If I get that far, I'll be over the moon :cool:Quote:
Originally Posted by Messiah
Someone please tell me how to change Vcore in this board ?
I mean when i set Auto and not overclock , it shows 1.325V , but when i increase CPU bus , it shows 1.425V , via Bios and Windows too
what temps did you have there? does a e6600 manage 1.70v?Quote:
you guys who has this board can teach me how to adjust Vcore.
Bios 0402 beta
My Bios setting are:
- SLI Broadacst Aperture : Disabled
- Nvidia GPU Ex : Disabled
- Linkboost : Disabled
- SLI Memory : Disabled
- All spread speatrum control : Disabled
In overclocking tab :
- CPU Internal Thermal Control : Disabled
- Limit CPUID Maxval : Disabled
- Enhanced C1 (C1E) : Disabled
- Excecute Disable Bit : Disabled
- Virtualization Tech : Disabled
- Enhanced Intel Speedstep Tech : Disabled
- LDT Freq : 5x
Vcore = auto or 1.325v
CPU Multi = 7 (E6300)
When i run bus 400 (1600 QDR) linked --> sync bus Ram = 800DDR2
Vcore in Bios and Windows was 1.425v
When i run bus 429 (1716QDR) linked ---> sync bus Ram = 858DDR2
Vcore in Bios and Windows was 1.525v
Any setting in Vcore is not affect , and the board seems automatic set the Vcore depend on the bus running
So anyone can help me ?
1.temps were round 20-25°C.Quote:
Originally Posted by Tuppen^^
2. obviously;)
