bios 0910 works fine for me.......
regards
regards
Originally Posted by Elisha
http://rapidshare.com/files/9317250/Asus.zip.html
Just Unzip it create a CD and call it P5B Series this shuld work
Let me know if it worked.. If it doesnt I can add more files :toast:
īLotzi try going back to the 804 from the 0908 or 0910 :fact: :mad:
says reading file P5BD.ROM from CD-Rom and then it says P5BD.Rom not found on CD-Rom.......looks like it needs more files from the CD.
is it possible that it needs more files from the CD?
because without the CD it says CD-Rom not found.
i get the same error message with my custom CDs as well with renames 0804 and afudos.exe in it.
Originally Posted by GrimReaper
why should i do this
i will always have the newest bios on my machine
flashing downwards is nothing for me.
all people who flashed 0910 are happy and works fine
and i dont said to all here flash 0910
i flashed it and i am happy
point........
ragrds
not blaming you here its a beta bios I know it comes with risks ;)Quote:
Originally Posted by īLotzi
I had the same problem. I used a floppy and the cd bios file. there is a ver file also that i put on floppy. that got me back running but with problems. reflashed to 0908.rom. back to normal now. not shure if ver file was needed or not.
Originally Posted by Hemi
can you explain in detail how you did it?
what files did you load on floppy?
Did u unpack/unzip the file first?
yep....extracted its content and burned it on a CD.
it seems to be looking for something else as well but not sure what.
maybe some startup files and not just the bios files.
someone pls hook me up with the entire content of the CD pls......i'm not sure the local PC shop would let me copy one off their retail stock.
Bios works fine here, system seems to run a little better in games, clocks are the same.
So is this new bios a fake? Where's the change log?
Originally Posted by jot
Placebo, but good to know it worked.
It's real, just seems to be kinda buggy...but then again, it's a beta. Unfortunately we don't have a changelog, so no one even knows what changes it's employed.Quote:
Originally Posted by T07N
"i will always have the newest bios on my machine"
Me too. I flashed others beta bios before without any problem.
"all people who flashed 0910 are happy and works fine"
No, I'm not. I recovered from bootblock.
Back to 908!
Anybody get to the bottom of this temp reading issue? I have my QX6700 on P5B Deluxe, just added Vapochill LS. LS reads -32c on evap, but bios and Speedfan always read -4c. Probe is really borked, always reads 252c, so I really don't know what my core temps really are.Quote:
Originally Posted by LarsK
Running 0804, 385 x 10, 1.456vcore (in cpuz), NB at 1.65v, RAM at 1155, 5-5-5-18, 2.4v. I'd like to try to lower the RAM multi 1 notch ('cuz it's about maxed) and try for more fsb with a bit more vcore, but how the heck do I read my core temps?
I just flashed to 910 with no problems. I see no difference in Oc or stability over 0908.
same here, no changes.
http://www.danasoft.com/sig/dan571.jpg
Originally Posted by vbo
Same thing here, well bootblock and bluescreens before that. I thought it was just me. Good to know it wasn't unless it'sjust a coincidence. back to 908 here too seems fine again. ;)
The vapochill temp reading is obviosly just the evaporator temp. The core temp may be closest to the bios reading. Pay no attention to any other reading except a couple of apps may report a minus temp closer to the bios incl MBM5 and maybe Everest in some versions. I have a vapo LS on a highly overclocked X6800 at 1.6v and my evap temps start at -48 deg and bios in the - 30's, so you may want to check your unit. Those evap temps seem high. Then again I see you have a Q, so maybe not.Quote:
Originally Posted by harvshark
Originally Posted by TuKo
my 0908 reads in the -30's in bios. ???? :confused:
What bios are you using?? I know that the LS temp is the darn evap temp. The point is that the bios and everything that uses it to read out temps shows -4c, and it doesn't change whether under full or no load, so it obviously isn't correct. How can I get the correct core temps? I have read in other threads that some of the bios's lock up at -4c at anything under 0.Quote:
Originally Posted by xgman
Somebody must know how I can get an accurate core temp on this thing.
damn :( the whole CD is 500-550mbQuote:
have you managed to fix this? :(
Can anyone direct me where to get the 0908 bios from?
Also are the bios for the p5bdelux and p5bdelux-Wifi AP interchangeable?
Originally Posted by mrt2
yes the only diff between the 2 is the WiFi card installed on the board.
Chaos thanks! =)
Now any idea where I can get the 0908 bios from?
