Originally Posted by celemine1Gig
No need to be sorry. I am not the one waiting for the mod. If you had no time to measure, you had no time. I can absolutely understand that as I'm also quite time limited ATM.
OK, now for the mod, I'd try a 1 MOhm (in words, one Mega Ohm = 1000 K Ohm) trimmer potentiometer connected between pin#16 and pin#17. With the trimmer set to maximum resistance you change the original value by about 6-7%, which should be OK. So, start with maximum resistance and then tune it down in order to lower the droop voltage. Hope it works.
