oops, first post upon waking up, math went out the window....lol
1mb per core would be neat tho
read the AMD tech docs. 512kb of L2 cache per core, 4mb of L3.
that makes sense, if the dual-cores are gonna have 2mb shared L3, then the quads should have 4mb...of course, 4x1mb L2 + 4mb L3 would be fantastic....for that extra 1-3% performance gain, lolQuote:
Originally Posted by breakfromyou
I have not seen anything about k8l having a 4 channel memory controller, or 2 dual channel ones. From my understanding k8l will plug into s1207 boards that are wired for dual channel, and whilst it would be possible for channels to be disabled for this purpose, it doesn't suggest there would be 4 channels, thus I'd put forward that there is a dual channel memory controller until proven otherwise.
Secondly where are these IPC numbers coming from? We don't know how much faster k8l will be clock for clock.
It seems almost definate that k8l will be a 4 issue design, so theres up to 33% improvement from that alone. I'm willing to bet there going to be some other small changes as well, but improving IPC is not something that you can do easily, and its not a task that scales linearly with the number of transistors your able to throw at the task. Taking into consideration your suggestion of20% higher IPC than kentsfield (which is optimistic):
3000 x 1.2 = 3600
If k8l was 20% faster clock for clock, it would take a 3.6ghz kentsfield to match a 3ghz k8l. AMD are aiming at 2.7-2.9ghz and traditionally amd don't leave much headroom on their high end parts.
You could buy a kentsfield today, overclock it and get k8l level performance. A year from now intels offering will have larger cache and faster fsb to keep the core fed, have a new chipset with a ddr3 memory controller, and possiby higher IPC with things like sse4 added to potentially speed thing up further.
I think the two will be very close on IPC, not a 20% difference at least, and intel will be clocked at least 20% higher stock, and have more headroom for overclocking.
Originally Posted by informal
I also think the new core will do great... I also think AMD isnt afraid to let Intel have the lead for awhile. Intel is in a race... AMD is just trying to make a great processor.
~Mike
I don't think so.. AMD is still growing, Intel has already grown. I also dont think AMD cares if Intel is ahead. Time will tell ofcourse. :-)Quote:
Originally Posted by brentpresley
~Mike
Um, is the answer half its l2 cache?(1 core accessing 4mb as opposed to 4 cores on 2 dies accessing on average 2mb each). The conroe dies shared l2 allows the full 4mb to be given to one core, so you could say its a gain of extra cache when using only 1core as opposed to a loss when multitasking, as a discrete l2 design wouldn't allow the core to get the extra cache. When running 4 apps its not neccesarily the fsb that proves the bottleneck. 50% extra cache for the 45nm core 2 variants should help out on this score.Quote:
Originally Posted by LOE
As far as i know K8L will have 25% faster IPC that Core 2 Duo. It all will dependo on how high AMD can clock them
I don't know about the other points, but you're obviously misinformed about the definition of IPC. IPC stands for "instructions per clock", meaning the average amount of instructions a processor can complete every clock cycle. Therefore, IPC is independent of the clock cycle. Anyways, given the improvements, a best-case 40% IPC improvement over K8 is not unreasonable at all.Quote:
i think that core will be 4*1MB L2 + 2MB L3. It will start in Q3 one Quad father. on L1FX+ with HT3, and DDR2@1066
AMD will release Barcelona first in H1 ( AMD press service told me ). Barcelona is for 1207, and AMD will release special Barcelona for Quad father. 4*512MB L2 + 2MB L3.
Don't cry because we can't use HT3 @ start. HT3 i very useless for moment HT2 for moment is not used to the maximum.
Next chipset's will be more higher clocked for HT2 i think. Ati can release very easely one chipset @ 1.5ghz even more.
I recommand to all who are waiting for a great product from AMD, to buy the X4 @ lunch and wait for DDR3 before any change.
Remember that HT3 is very useless for moment.
IMO....
If intel has the lead for awhile, so be it. I've never had a top of the line CPU so I don't really care much. AMD makes plenty fast CPUs for most things now, and if K8L is that much faster than K8 it will be awesome. Just because intel's chips may do better in benchmarks doesn't mean there will be that much difference in real life usage. Only purpose of those better benchmarks are for bragging rights ;)
My :2cents:
I got this at the inquirer also. Read it there is one statement that got my att. See if it gets yours. Because of that statement. K8L has to be a 4 issue core. Or the afore mentioned statement is completely false. I don't know if true or false. Only that its very interesting.
http://www.theinquirer.net/default.aspx?article=36017
As for Yorkfield being native or not. I believe the other reports that are out . Which all stem from IDF or the same timeframe. NO eirlier or latter sources. York will have Shared L2 cache among all 4 cores. If that = Native it will be native . If that = something else thats what it will be. If all the reports are correct about york . the best we will see is a 10% improvement in performance.Clock for clock
If Inquirer got it right on this link . York will be slower than K8L. I personnlly don't care which it is. I am more interested in who is putting out the more informed info. So we all can recognize and expuse more aeg members.
ok the info i got long time ago is mostly:Quote:
that k8l will have 2x256kbit FPUs
but real k8l (at that time only one k8l existed)
Ya that was the one . . What is that 300% improvement over k8. I would think that 4 issue core would be required or it would be bottlenecked.Quote:
uh, if you double the number of cores, the IPC should also double, aight?Quote:
Originally Posted by Shadowmage
and if you are talking about K8 vs K8L cores, 40% IPC improvement is not unreasonable but still pretty far fetched.
Don't think so. The number of decoder is not the number of issue that i heard.
AMD X4 will have four complexe decoder, easy to see it on die shot, even on the low res die shot.
I think that the number of fetch, is the number of issue. AMD don't go to 4 fetch, but the fetch will be 32bits instead of 16 bit of deep.
AMD may transphorm some simple instructions in one complexe. I think so. If any body have some news more fresh :stick:
thx
wait :slobber: & see :clap:
This is from the articleQuote:
It also supports dual 128-bit SSE date flow, dual 128 bit load per cycle,
What does k8 have. 64-bit SSE date flow. If this info is correct thats a 300% improvement.
You would need "double Fetch" which K8L just happens to have
not a 4th integer stage
while reading the posts I was hoping somehow not to see C2D named.. but this time is not an exception.. :clap:
INQ is like broken phone. Collects pieces of rumors and puts all together. :nono:
what about integer in X4 ? I don't read anything about the question :stick:
