i wish i had some more free time to start a 3stage too ...
Good luck and have fun with your build ricky! :toast:
1 hx done i need to buy more some meters of 2mm cap to finish the other hx, gauges for 2nd and 3rd ready! some other parts buyed
http://img116.imageshack.us/img116/5013/partshn2.jpg
smal hx :D 2.5meter of 1/2 with 5 2mm caps inside
it must be enought no? it must have more contact area than 5meter 1/2 with 1/4 inside
http://img461.imageshack.us/img461/1454/hxyf7.jpg
:toast:
dont you know that price of this evap (copper + the time you need to make it) is more than a plate HX ?
you can find plate hx for good price 50 €is an average
on ebay you find lots of plate hx n like here http://search.ebay.de/PlattenWaermet...rkwZkompressor
well it is a good ideia, but now i'v the cooper and i'm trying to be quick on this cascade :S
about the plate hx what is good? 20kw? 50kw?
about the size there is no problems, this ones i made it's more than ok, will a plate hx like this ones perform way better? i never uses one :(
need to get one to test
Oh you will love plate HX...
last night 200W heatload on my load tester which seems to be on "hot" side of story... SC15CLX/SC12CLX combo which is considered small in cascade held -89.5c on evap :) Not quite done tuning yet though :)
hummmm :banana::banana::banana::banana:!! only you guys to :banana::banana::banana::banana: my brain :S i'll make it with this hx's becouse i need it ready quick and bu from ebay need more 1 or 2 weeks to have it @ home...
but later i'll buy plate hx to try :P anyway i think this hx's have quite good heat exchanger area. i like it very mutch on predator cascade
:toast:
Hell No! :DQuote:
Originally Posted by |RickY|
That's way too big! ;)
'Bout 5kW is more than enough! ;)
heheeh the most i found on ebay was 20kw or more :D
So on the subject of plate HX's...is there any disadvantage of using one rated more than 5kW? Would it affect performance if you used one rated a higher kW?
i think it will be better under load
so 4kw or 5kw is enough
Definitively NO DISadvantages :) except needing more space! ;)
...and higher price :rolleyes:Quote:
Originally Posted by 404Power
Actually... try 1/4hp compressor with huge ass condenser... Same concept on oversized plate hx... at least for 2nd stage... :)
All the basic behavior of ss applies directly on cascade too... except... you do have variation due to 1st stage in this case... :)
make the dieffrence btw both , you will see:toast:Quote:
Originally Posted by LukeXE
copper price always increase
plate hx are not so expensive finaly
dudes, i try to change the sc21cl i have on my 2nd stager by the rotary, Simply power!
awsome. it handles amazing load on vacum!
6800 near 5ghz @ 1.92v:
i jump from -8x with sc21cl to -100 full load on 3d action with rotary :o
this is on my 2stager with rotary on 2nd
some pics:
http://img82.imageshack.us/img82/5831/104biosmw1.jpg
http://img87.imageshack.us/img87/3239/115gj4.jpg
idle on bios:
http://img87.imageshack.us/img87/552/fluke1xp3.jpg
WOW some awsome temps. Any pics of the final setup Ricky :D
it was just a test, that compressor will be for the 3 stager. more pics later :)
thanks
hx's ready to rock no plate$ hx's for now
http://img113.imageshack.us/img113/4821/hxsul4.jpg
|RickY|that -106 in bios temp is with 2 or 3 stages? i got a bit comfused!
Thats on his 2 stage mate, i got a little mixed up also.Quote:
Originally Posted by esdee
ok, im one temprature post away from starting my 3stage...:eek:Quote:
Originally Posted by 4Qman
hi bros :) i need your oppinions about 2 questions:
1st: i'll use 1 pipe for desuperheat each stage, anyway will have so many ones for 1st stage condensor, can it be to bigger?
here the foto of condensor:
http://img124.imageshack.us/img124/9...rementsuk7.jpg
2nd: i'm thinking on 12000 btu compressors for 2nd and 3rd stages, i can buy it more cheap if comes with mineral! if i add some propane for oil carry it will be ok or i must drill and hole on carter and change for poe oil? or save more money and buy poe compressors?
i'm thinking on r404a/ethylene/ethylene and after r404a/ethylene/r14
isn't mineral oil ok for ethylene ?
so buy one and one with poe oil
to drill a hole, maybe it's a bit too extrem, isn't it ? :D
I know we're on Xtremsystem but... :D
I would buy compressor with mineral oil, for sure you can add some R290, it will carry oil with pleasure, however, you must install oil separator just after compressor, so oil type isn`t problem.Quote:
But don`t know how will R14 react with mineral oil, I know that with POE it worked quite good, maybe with mineral it will work good too.
