unbeleivable....I mean...i have no words for all the work you'r doin!!! u man are awesome! congrats!!!
Marco
Marco
good work!
thats great that project... keep going with the good job
Any time on the compliments. Credit where credit is due I always say. :toast:Quote:
Originally Posted by endscape
Far as the rack goes ,,, I find that hard to believe. With your skills I think you could easily make a very nice HDD rack. Seems to me most make it out to be much more complicated than it really is. As example, here is one I fabricated a couple years ago from scrap that was sitting around my shop. Being used right now. Required some welding, which is not something most people have access to, but a similar design could be made with nut & bolts as well.
http://img156.imageshack.us/img156/1...nish9vq.th.jpghttp://img151.imageshack.us/img151/8...ys179qm.th.jpg
As you can see I like to think outside the box. That design seems to almost totally isolate vibrations. Only the mounting screws touching the drives. And the rack is mounted on the case floor on acoustic foam. Even with the WD Raptor in there I have to put my ear down close to hear the drives at all.
interesting way to mount the hard-drives.
im thinking about using a peice of plexi glass and then some rubber between the hard-drives and the glass. maybe some acoutstic foam in the hard-drive cage as well.
Nice work . If you have the tools all things are possiable. May I ask how much your Dad is helping?
Very good planning nice layout.
This thread should be a sticky. On how to self build a case the correct way.
Nice work bro. Your future looks promising.
South Australia eh? How's the golf down there? I've always wanted to go on a little vacation :toast:Quote:
Originally Posted by Mortal
You have inspired me. I've got a couple plans, but nothing definite, so we'll see how it all comes together. I'm going to try to get the rest of the chassis put together before I tackle the hard drive racks. And welding, well, that isn't a problem haha.Quote:
Originally Posted by Susquehannock
He helps in so much as if I run into a problem that I cant seem to wrap my head around I'll bounce some ideas off him. He hasn't done any actual cutting/ drilling/ riveting/ anything physical on the case.Quote:
Originally Posted by Turtle 1
So try this one on for size. A couple weeks ago I get a bad case of strep throat, like I've never felt this bad ever. So I go to the ER, get pumped full of fluids and get prescribed some wonderful medication. It works and I'm back up to snuff within 5 days. Five days after that, it fracking comes back. So I am sick once again. I got a little work done in between, I'll post the pictures right quick.
On another note, I'm looking for other boards to post this at since I'm trying to get as much coverage as possible. Any suggestions? I'm already on H, Bit-tech, and Gideontech.
OCAU (Overclockers Australia) - Worklogs and PCDB Entry Discussion (http://forums.overclockers.com.au/fo...play.php?f=52).
Anand tech has a really nice case section. Lots of readers . Toms Hardware also.
Just so you know this should be a sticky here. I was surprized when I read it a weak ago. That it wasn't made a sticky.
Hope your feeling better soon.
http://anandtech.com/
http://forumz.tomshardware.com/hardware/
http://www.fusiondesignlabs.com/orac...n_DSCF0001.jpg
Well, it was $30 more than I wanted to spend, and longer then would easily fit, but I like it none the less. I'm always impressed by the build quality of Black Ice rads. Happiness abounds.
http://www.fusiondesignlabs.com/orac...n_DSCF0013.jpg
A better angle of what's been cut thus far. I wont be cutting the holes for the PSU and the radiator shroud whatchamacallit until I get the shroud built and the radiator mounted to make sure everything lines up right. Tomorrow I'm going to rivet the rear and bottom panels together, I'm going to go with a single long bracket like the side panels as opposed to three small ones.
http://www.fusiondesignlabs.com/orac...n_DSCF0005.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0012.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0016.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0018.jpg
Building the motherboard mounts. The JB Weld should be all set up by Monday, so I'll be able to grind off the excess and give it a much cleaner look. Tomorrow's plan is to get them installed and get the cross support rod in place.
http://www.fusiondesignlabs.com/orac...n_DSCF0026.jpg
Mmmmm...I think there might be a few projects in there. The coolest thing is a box of wifi cards that form a secure network amongst themselves only, looks like they could yield all kinds of interesting adventures. Did I mention it was all free?
Thanks! I'll have the log up there in a couple minutes.Quote:
Originally Posted by GAM
I dont think its quite sticky material, but I'd certainly be honored.Quote:
I realy like your project! very good designs made!
Looking at the project i think i can learn much from it.
Keep up the good work!
http://www.fusiondesignlabs.com/orac...n_DSCF0025.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0009.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0010.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0017.jpg
http://www.fusiondesignlabs.com/orac...n_DSCF0019.jpg
very nice work
Looking good so far. Nice of you to share images as the project progresses.
I made a thread about your case a couple of weeks ago at this forum, I just linked to this thread. I am sure they would love to see your work log. http://www.ocforums.com/forumdisplay.php?f=20
Yes, that is how I found my way here Cole. Thanks
Haha, that's awesome. I cant believe how much interest there is over there! I brought my project log over.Quote:
Originally Posted by Hey_Its_Cole
Why hello there my stalkerish friend!Quote:
Anyway, I'm sick and my Dremel broke. Yeah, life pretty much sucks. After two bouts with Strep throat my neck is killing me, I have no energy, and my lymph nodes are swollen like all get out. I've got a doctors appointment in the morning, so hopefully they can figure out what the heck is wrong.
No idea when I'm going to get around to work on Oracle, I'm hoping to get it ready for paint before I go back to school, so I have lots and lots to do.
E
first you get shot... then you get sick... then you get sick again.
This case is cursed!
This may be true. And now my webhost seems to have died!Quote:
Originally Posted by spudnik
Originally Posted by endscape @ hardforum
<-- Can't see any of the pictures?
I'm aware, dreamhost is working on restoring them.Quote:
Originally Posted by Lurid
E
Pls upp the old Pics again if you still have them.
Can't see the photos! :(Quote:
Not Found
The requested URL /oracle/18/vid/ was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
For crying out loud people, I'm working on it! Its takes some time for dreamhost to work its magic.
