It is test for nothing, pretty old bad MoBo, bad overclockable Kensfield ES, lot of pictures says nothing. Sorry, but in this post is not nothing to interest.
Agree. :rolleyes:Quote:
Originally Posted by OBR
well, why dont you post some quad core action then...
is 16 second superpi1M @3.1 ghz very good?i think so or am i mistaken.
my allenadale 2MB cache @ 3.8 scores 15 so...
There are not many other people (if not none) that test their hardware so thorough as eva does. If there's nothing interesting in it for you please just read on.Quote:
Originally Posted by Ashraful
Of course, YOUR contribution to this thread and this site can be called revolutionary :rolleyes:
If you don't like what you see, why even bother posting :nono:
Continue your work plz EVA2000, for everyone else who does like what he's reading and what you're trying to investigate.
nice work!
can u do dvdshrink?, like u did i the other thread..
@ t-break looks like dvdshrink takes advantage of the 4 cores,
http://www.tbreak.com/reviews/articl...5&pagenumber=5
anyone have a link to system tools? nice work eva .
thanks loc.o and thorgal
It's nice that this thread is appreciated :)
I've swapped my E6600 out and Q6600 back in for some X1900CF/X1900XTX testing for now. Asus P5B Deluxe has been ordered and awaiting delivery and also eVGA 680i and eVGA 8800GTX samples for review/testing are on the books as well so pre-Xmas fun is coming :D :toast:
Ah yes dvdshrink tests...amazing how this old app can take advantage of 4 cores too! Will get around to dvdshrink tests with the same dvd again http://www.xtremesystems.org/forums/...d.php?t=107518 for you a little later :)Quote:
Originally Posted by NapalmV5
vanovich, thanks you can find systool at http://www.techpowerup.com/systool/
thanks eva2000,
I had been looking information whether badaxe 1 support kentsfield.
Heya eva, you may want to check out my own investigation though the BIOS I used is older so I am really not sure about how similar or different it will be compared to yours.
You can find my investigation here: http://sleektech.nl/~dm/review/intel...x-note-04.html
You may want to check the previous and succeeding pages. Good luck.
Btw, if you want to break 350FSB++, use Bad Axe 2 :)
Here's my multi-only overclock
http://valid.x86-secret.com/show_oc.php?id=130172
http://valid.x86-secret.com/ccpuz.php?id=130172
the XBX2 maxed @ 390ish with Q6600 (470fsb on P5B DX) for me :( (afaik FUGGER have same issue) ... nothing a bios can't fix :)Quote:
Originally Posted by death metal
XBX2 is awesome with conroe :slobber:
roomtemp 22c
E6600 "ES" Step 5 B1
Intel Bad Axe 2
2gig Team Group 667 "D9"
Tuniq Tower 120
OCZ GXS 700W
XFX 8800GTS 660/1000
1M
CAS3
prime :eek:
this board is a keeper :fact:
thanks guys
Thanks death metal added your notes to my semi official d975xbx thread http://i4memory.com/showthread.php?t=2804 :)
XBX2 looking sweet!
great work eva.. :)
:woot:
Thanks..
Moved onto P5B Deluxe and my Q6600 now capable of a much higher fsb :)
To start 3500Mhz - 9x389FSB quad stressprime at 1.4000v (1.5v set in bios, 1.4720v windows idle droop to 1.4000v :eek: )
Idle
http://fileshosts.com/intel/Asus/P5B...uz_idle_tn.png
Load
http://fileshosts.com/intel/Asus/P5B...me_load_tn.png
Seems 2nd cpu on the Q6600 with cpu2 + cpu3 run alot cooler than cpu0 + cpu1 :)
ha, finally u got a P5B DL, u need vdrop and vcore mod :D
unfortunately it's about the same for me :(Quote:
Originally Posted by eva2000
Yeah.. do you know of a pencil mods for vdroop and vcore for P5B Deluxe rev1.03 ? since i don't know how to volt mod, just have to use stock P5B Deluxe.. not bad
@3600Mhz - 9x400FSB
PCI Express Frequency: 100
PCI Clock Synchronization Mode: 33.33Mhz
Spread Spectrum: Disabled
CPU Vcore Voltage: 1.550 (1.488)droops to 1.464v
Memory Voltage: 2.25v
FSB Termination Voltage: 1.4v
NB Vcore: 1.65v
SB Vcore (SATA/PCIE): AUTO
ICH Chipset Voltage: AUTO
Memory Remap Feature: Disabled
Configure DRAM Timing by SPD: Disabled
DDRAM CAS# Latency: 3
DRAM RAS# to CAS# Delay: 4
DRAM RAS# Precharge: 3
DRAM RAS# Activate to Precharge: 4
DRAM Write Recovery Time: 4
DRAM TRFC: 25
DRAM TRRD: 6
Rank Write to Read Delay: 10
Read to Precharge Delay: 10
Write to Precharge Delay: 10
Static Read Control: Disabled
Modify Ratio Support: Enabled
Ratio CMOS Setting: 9x
CIE Support: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM function: Disabled
Execute Disable Bit: Disabled
PECI: Disabled
http://fileshosts.com/intel/Asus/P5B...lidated_tn.png
http://fileshosts.com/intel/Asus/P5B...7s157ms_tn.png
Quad Super Pi 32M
http://fileshosts.com/intel/Asus/P5B...m_quad_tnn.png
:D
you must be blasting the :banana::banana::banana::banana: out of this CPU with your portable aircon..........11C LOL
nah bug with asus probe2 and the bios reported temps - same prob here http://www.xtremesystems.org/forums/...d.php?t=122316 with kentsfield
only coretemp works properly right now
oh i see
Ditto, I also find Eva's detailed results on BadAxes to be very valuable.Quote:
Originally Posted by thorgal
A++++++++++++++++++++ work man!!!!
i wanna see DI XD
thanks guys... DI heh maybe one day who knows :)
Eva2000, can you tell us if you plan to get a BadAxe 2?
no sure if i will right now... unless intel takes notice of me and sends me a sample LOL
