Exactly what performance numbers are you talking about?
Really? Well I don't see it in
johnnyguru.com's review either.
It's true that SPCR haven't included it in every test earlier,
but now they do. They also checks out what happens if the VAC falls down to 80 - 90 V, if the PSU still can deliver a proper output. I've never seen that anywhere else.
I'm surprised that you're not interested if the fan can keep the PSU cool and work properly under heavy loads. You saw what happened to that Mercury PSU (not saying that it must be because of the fan). The best way to test it is to feed the PSU with the heat from the components it's powering. Not all heat though, since some of it usually goes out through a case fan. But if you never put a PSU in a case it's less of a problem. I'm not sure if Activehome put the PSU's in cases, but if they didn't then it wouldn't surprise me if some more PSU would fail during the tests. The intake heat makes all the difference.
SPCR always gives you the values (V & A) for each rail at different loads, up to maximum load.
