The 5V/12V mod doesnt simply work with a 100K pot? I used it and the only sound my PSU made was a sissling sound from the mosfets... :confused:
thats a bit worrying, did you definately connect it to the right pin of the ic and the right legs on the pot, all i used was a pot and it worked fineQuote:
Yes I did connect PIN 1 of the TL494CN to a 100KOhm variable resistor and to a 'ground'pin (actually the 'ground' lines on the PSU itself)Quote:
Probably I got the wrong pot, need to have a more heavy one I think! (The one I use is a small rectangle, blue, gives about 20 turns and is very small. (Probably I need a very big turningpot/ trimmer...
Same problem here as Stinger666, connected as in diagram, get a short (sizzling sound).
Maybe these newer qtec are different, anyone got any other links to 12/5v qtec rail mod??
Hey i have a 450W q-tec dual fan psu and after examining it i have found the "IC2" on which pin one needs to be connected to ground. Also i think the place i have marked ground is connected directly to ground so i'd say i could use that. Only thing is IC2 is almost impossible to get at, how could you guys solder a 100k resister to it?
Look at where the pin comes through the back of the pcb and solder your resistor to that
I hope thats what u mean solution just seems to easy???
Ok thanks i'll give it a try.
Hi,
I've read some stuff about voltmodding this baby..
My voltline are very stable and relative high, 5V rail is always over 5V with cpu @ 3Ghz full load (NF7-s)
12v is also ok..
but 3.3v is around 3.30-3.36 under idle and doesn't actually change much under load, I use 2*512 BH5 with Vdimm connected to +3.3v..
I'm stuck @ 240*12 wich give me 35 sec super pi..
I really want those 34s so I want some more juice for the BH-5, lets say 3.5-3.6v..
Which was does really work?
12Quote:
The 3.3v is a done deal I can get that up with a Diode on
the 3.3v sense and a resistor change on the board
Replace R28 with 10 Ohm..?
Thx in advance!Quote:
Its CP431 which control 3.3V feedback lines. You put 10K VR in parallel to R56 ( blue resistor located between CP431 and black wires ). Slowly turn the VR to lower resistance, and you will see the 3.3V line goes up !!!
Anyone?
