Yes Good point there Walt about the soft solder, do you mean the plumbing type solder?
One thing I do these days to improve subcooling a little is the heatshrink on the last part of the ss before the evap, most of captube is coiled in that area and it pulls it nice an tigth there.
This unit is tuned and ready, Im really happy with the way its running, compressor temps is good, pressures and temps good also so I wont dissasemble now for the soldering of captube.
Lastly, you ask about the accumulator, its not a filter its only an empty shell that privides a little volume there that is really needed because the suctionline is shortish and the captube a few inches shorter than usual. I can give little more refrigerant there without too much worry about liquid return. I have frost all the way back to the end of the accumulator on idle and if it was not there I would have had liquid returning. The bit of wrapped captubing around the accumulator also helps with evaporation there.
Too all the rest of comments, always appreciated :D
