Originally Posted by jaguarking11
I use more than a couple of 90 degree bends in my loop. My system is happy.
Hell my whole loop is copper.
I think allot of this theoretical crap does not impact performance as much as you make it seem guys. I understand this is xtreme systems and all but sometimes one or two degrees can be negligible when there are more factors in a loop than just tubing size. (I cant believe I said it myself) Tubing size and flow rates as well as head pressure don't dictate performance alone. Its a combination of those factors coupled with surface area to produce a high performing loop. You can have all the pressure in the world as well as a great water block and if your rad is too small for the heat load then your performance is crap.
My .02c.
