I personally am Very curious how exactly that happened. seems to me something like that shouldn't happen. And part of me wonders why it did.
wth.. inductors are pretty near impossible to blow. although PC power and cooling seemed to have an inductor problem a while back.
the glue probably caught fire.
Alright. I'll try to explain as clear as possible.
I was at
1.3v LDT
1.7v chipset
305fsb @ 1.55v*104% (=1.612) vcore
To add more cooling I hooked up a 120mm delta fan (Model: WFB1212HHE dc 12v 1.00A -F00 ) to the molex before my hard drive.
I have an OCZ 520W power supply, and that molex line was only connected to hd and that fan.
I powered up and went to the bios, changed the settings to:
310fsb @ 1.55*113% (=1.7515v), saved and exited.
Now I'm uncertain if it turned off by itself here or not.
But after it was off, I tried to turn it on:
one red light came out for about 0.4 seconds and it turned off, I tried once or twice more, but it wouldn't budge, it was like trying to start a car when a battery is too low.
Then I switched cmos jumper, took out battery and tuend off psu.
After a few seconds, I turned on psu and attempted to turn on the pc again.
Same thing, but I heard something hiss, then on second try, I saw sparks/fire fly out of the are where I took the picture posted above.
I instinctively unplugged the power cable out of the psu.
I thought it was a capacitor because it was the same smell I once sense when a capacitor blew on a video card.
OH yea, it's a LanPart Ultra-D nf4u91-100 R.AB0
I did some tests so... Well my case door blew off my case just a few hours ago from setting the vcore to 2.1v. =P That may have explained what really happened. XP J/K
your not suposed to take the battery out of the lanparty boards it mucks with their voltage settings read a few threads on this at dfi-street thats most likely what happened aparently if u remove the battery it can send about 2.0v to ur chip and possibly smoke it.Quote:
Originally Posted by KoHaN69
negative. I've taken out the battery in my motherboard dozens of times, even while the board was still on. (yet this wasn't one off them, the board was off).Quote:
Originally Posted by Juggalo_X
And the strange hissing follwoed by immediate turn-off was apparent before I took out the battery.
Good thought though, nevertheless
Sombody doesn't know how to properly clear a DFI NF4 CMOS!!! :p: lol but he is right, pulling the battery is actually considered part of the standard way for DFI.
I really doubt it was the Vcore, heres waht happend to me this week.
Accidentaly put Vcore @ 1.525*136% instead of putting it on 1.525*auto. My opty took alost 2.1v for about 30 seconds until the thermal protection (60C) shut the machine off.
Pretty stuypid yes :slapass: :D
The proper Clear CMOS for the Expert/Venus board always included the following warning.
When performing a Clear CMOS, always replace the battery before moving the jumper back to the "normal" position.
This allows any current surge from the battery replacement to be shunted to ground when the battery makes contact.
Check the voltage on your CMOS battery, if there was indeed surge current which smoked the inductor, your battery should have discharged completely or even blown up by itself.
I doubt his case has anything to do with the battery.
AS I said, the smell and autturnoffs started occurring before the battery switch
and the battery is still good.
Good thinking though
DFI found nothing wrong with it O.O
ex:banana::banana::banana::banana:in'cuse me?
qftQuote:
Originally Posted by nn_step
I just got it, left them a message, they'll call me back.
There's no way I'm gonna put any of my parts in it.
U mean they didnt even notice that blown inductor?
weird
Heh...you'd think they'd pay attention to something like that.
Inductors don't burn due to electrical stress because there's actually nothing that could burn for an inductor is just a coil of (thick) copper wire wrapped around a ferrite core.
:confused:
It's not blown, it lit on fire.
and largon - you are full of boloney ;) anything and everything burns
pfft self proclaimed xtremist :p: :D
they replaced the chipset on it (they ay it was overheating)
Hope nothing else goes wrong :)
Crank it until it breaks
vcore @ 1.8v ? :slap:Quote:
I http://images.google.com/images?q=tb...ault/heart.gif my opty :toast:
I made a duct so heat should never be an issue
http://xtremesystems.org/forums/showthread.php?t=124032
/*close thread */
