Sorry if i confused you guys, it was a bit late when i made the post and i was out with Gorillakos drinking a couple of beers :rolleyes:
Originally Posted by T_M
The ID is 66mm all the way down to the bottom (untill where our bottom design begins) they are not solid from the holddown and below
Cu Container original Diameter was 80mm :DQuote:
Originally Posted by Dani
66mm ID + 5mm wall on each side gives tube OD 76mm ;)Quote:
Originally Posted by G H Z
again utill the holddown we have tybe OD 76mm, adding 2mm on each side for the holddown we have tubes original diameter 80mmQuote:
Originally Posted by Extera
(thats why the copper isn't so clear from the holddown and below ;) )
:toast:
