Hmm..
I need him to run Quad SLI in order to figure this out.
Hmm..
There are no HACKED SLi drivers out there right now that Support 7950GX2..Quote:
Originally Posted by Rol-Co
So...... huh?
Turn on soft-shadows...turn on everything, lol. That's about what QSLi does at 1920x1200, just barely breaks even.
Also, try turning down settings and repeating those tests, if QSLI scores a lot lower, it's on. (the converse is not necessarily true though....if it's the same scores, doesn't mean it's off ;))
Originally Posted by Complete
Like i said......you need nvidia's quad driver , and on an intel rig they must be hacked.
here are the quad drivers
http://www.slizone.com/object/slizone_quad_beta.html
Thats my fault. I misunderstood you.
We are talking about the same thing :D
There are some hacked SLI drivers for intel out there.. but none that support the 7950's.
But this driver does support Quad SLI.. Its just not on Nvidias site yet :D
Only if we could get this version tweaked :D
Complete, will you try the 92.91 drivers also? Here
Ok, thanks to Complete for hooking me up w/ 3Dmark06.
God damn these tests are long LOL.
This is w/ 1 card.
http://img502.imageshack.us/img502/5...mark06atk2.jpg
erm just run the standard test, if you change the settings you will get a poor result... you only need SM2.0, CPU test and HDR/SM3.0 test for your score, rest are just redundant
it was on the nvidia site , that quad driverQuote:
but only support for nvidia chipsets.
i got a pretty new hacked sli driver here but don't think it support gx2 indeed.
maybe someone can hack this quad driver.
@vudoodoodoo
wtf :eek: 133k aqua with a 7950gx2 ?? what did you do? running dual prime in the background????
look at my sign :D
Yep. After seeing this post. I ordered a Asus p5w64 mobo..Quote:
Originally Posted by Reinvented
It will be here early tomarrow morning. I will be doing several tests myself. It seems that I think Quad SLI might actually be working.
If not. Ill send it off to Big_sam. He knows / or hacked himself the other Intel Nvidia drivers found on XS.com;.
Since Quad SLI is in theory enabled.. I think hacking them to the Intel chip will be alot easier. :)
:banana::banana::banana::banana:ty RAM ftl. :(Quote:
Yea.. Get some new ram bro!
Any new test results??
Run the default 3d06 test..
COME ON!!
Asus P5N32-SLI-SE , x6800 @ 4g , and 2 gig ram,
My quad sli setup can hit 11k on 3d06!!
Right now.. with my Asus
My RAM is in the mail. Fedex Home is soooooooo slow.
I'm still running 3DMark.
God I feel bad for people who do reviews. Running benchmarks all day... SUCKS.
Single Card
http://img231.imageshack.us/img231/3...mark06bie9.jpg
Both Cards
http://img244.imageshack.us/img244/5...mark06bic4.jpg
:stick:
Kinda dissapointed. :(
But having the option to enable it in the Control Panel seems promising. Maybe it will be easy to hack it or there will be official support real soon.
Originally Posted by vudoodoodoo
Okok... wow..
Run a test with ALL default values.. including resolution..
But it appears... No luck with the quad Sli...
dont think its working :S
I hope your CPU is not bottlenecking you...
I'll try again later. I'm tired of benchmarks right now LOL.
a conroe 6600 cpu is bottleneck up til 3700mhz with a single 7950gx2, you need some power or high resolution.
almost 11k 06 with single gx2 so both must be more around 15-16k if its working ok.
but don't think it work's until it is hacked.
PCI E will run as x8 (slot1), x8 (slot2), x4(slot3), x8(slot4).Quote:
So slot 1 and 4 will be better.
Would be awesome of someone hacks this drivers.
Man imagine kentsfield + 2x 7950GX2
I see. I'll try again this weekend when my RAM comes in.
It's not working....at 1920x1200 you should see some positive difference in the GPU tests. His CPU is not a bottleneck.
i dont think it works
the 1st post which he made last night showed the "Enabled SLI" on the forceware control panel. i think that one only applys to 1 GeForce 7950GX2, which is SLI on a single card. I tihnk he messed up SLI and Quad SLI. nvidia doesnt even support SLI on 975 let alone quad SLI....
i wish htey do cuz then i can keep my 975 and have official support for SLI at the same time
No, it shows "Enable Quad SLI". I had quad in my AMD setup before this one and it shows the same exact thing.
When you have 2 normal cards, it says "Enable SLI"
When you have only 1 7950GX2, it says "Enable Multi GPU"
