@ funkflix & TaPaKaH
he's using 2gig
he's using 2gig
Did not missed that. :)
Nice ram and nice work Mic :toast:
Can you run those crazy speeds 3-3-3-8 timings with higher multis and same stability on p5b? Ever try those sticks for max LL on p5wdh? These LL frequencies are getting up there quick. Looks like the bh5/high voltage days are back :)
Thanks Vince,
7X517 is also OK, i'm wainting for stronger VGA to put the CPU under phasechange. AW9D-MAX is also on the way for some 975X action :).
Edit: a little update, 3.21V:
http://www.crazypc.ro/forum/attachme...7&d=1159520778
nice rams you got there.. :D
:woot:
3v? This is the way back to the old school :D
nice results there mate......
And some Everest benches at 520Mhz 3-3-3:
http://www.crazypc.ro/forum/attachme...9&d=1159527893
http://www.crazypc.ro/forum/attachme...0&d=1159527893
http://www.crazypc.ro/forum/attachme...1&d=1159527893
Nice! :toast:
Did u set the CL 3 out of Bios?
Yes, boot at 510 Mhz 3-3-3-8 and then Clockgen adjusted; i don't love the P5B that much tho', sky-high FSB but poor performance, plus it's rather picky with dividers.
awesome !!! great job . Micutzu !!!
