if there is rivets u can probably just drill them out and take the cage out.
EDIT: nice and shiny!!! i like it. keep it up
Advanced Batch Converter:rolleyes:
I finaly got my last radiator so the project is up and runing again.
some pics:
http://imgs.bandwidth.se/razzz/imgs/Chassi/91.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/92.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/93.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/94.jpg
Nice:up: I can't wait to see the finished product:).
Looks great! I can't wait to see how well the PA120.2 fits in the bottom.
I'm hoping to do a build much like this one myself
Just drill out the rivets.Quote:
Originally Posted by serious1
Tnx all
New updates.
Due to some scratches on my outside I had to do it all over again.
I cut out some holes for the second radiator at the bottom and fixe the mountings.
I allsow attached the pump on the 5,25" bottom.
Pics:
http://imgs.bandwidth.se/razzz/imgs/Chassi/96.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/97.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/98.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/99.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/100.jpg
Um, problem. You're NEVER supposed to have your inlet facing down, EVER.
It´s my outlet which face down?
yea that outlet
yes, so no problem there. Exept it looks like it will be a(two) thight bend from the pump to rad....?
Oops, I was looking at it wrong. Sorry :(
New update finaly. I started to work on the reservoir today. I will use a "T" at the bottom so this I just to make it easier to fill it up. I put it on the side of the 5,25" so I had to do som modification with case.
http://imgs.bandwidth.se/razzz/imgs/Chassi/113.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/101.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/102.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/103.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/104.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/105.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/106.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/107.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/108.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/109.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/110.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/111.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/112.jpg
wow that's pretty heavy right?
awesome work :toast:
For a G1/4" fitting what size hole do you drill?
Tnx!
Yes, the computer will get pretty heavy :D
I used 13,5mm for the hole.
Finnished the reservoir today. Allsow put some wheels on the case.
http://imgs.bandwidth.se/razzz/imgs/Chassi/115.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/116.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/117.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/118.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/119.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/120.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/121.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/122.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/123.jpg
sick build man !! wow.
upside down D5 = not so optimal.
as long as inlet doesnt face down u can mount any way u want!
So no problem there!
I figured you would have cut the fan grill out of the back of the case. Just to allow for a tad better airflow. Other than that, It looks great. I really like the res.
Almost done...
http://imgs.bandwidth.se/razzz/imgs/Chassi/125.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/126.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/127.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/128.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/129.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/130.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/131.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/132.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/133.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/134.jpg
http://imgs.bandwidth.se/razzz/imgs/Chassi/135.jpg
whoa! :clap:
holy :banana::banana::banana::banana: balls
totally amazing! Nice work on the piping, dang that must have taken a lot of work.
wow that is an excellent job you did there :up: . you have inspired me to mod my centurion now:) .
