That was just the dimm that Micron will make and yes you can use DDR2 ECC on your intel and AMD systems. If your motherboard dosen't support ECC, then the ECC part of the dimm will not be used but the dimm will work. ECC dimms have a extra mem IC on both sides that makes it ECC so you can make a dimm using the same memory ICs for a DDR2 2 gig dimm with out ECC.Quote:
Originally Posted by Deathspawner
