I've been doing this all along with Xtreem DDR2-667?! :confused:
Hmm I havent ever tried above the stock 2.1 on mine and there just max for this mobo :(
FSB wall is at 462 so I run em @ 460 just to make em happy and cool running, mine are also Neked :p
So seccy
Sweet! My 667 3-3-3-8 can do atleast the same 3-3-3-8 800 @ 2.3v. Though im running a DFI Infinity so i cant go much over 500.Quote:
Originally Posted by Philosophy
I know there is potential to go a lot higher because the comp craps out @ 379 CPU fsb and that means ~520 DDR. With any divider i use the cpu fsb can´t go higher than 378.
at 2.25v with a 2x1gb kit? ;)Quote:
Originally Posted by lopri
any idea of when these will be out?
I was hoping for D9GKX when I read the title :p:
Correct.:)Quote:
Originally Posted by ozzimark
And btw, with DDR2 there is nog difference between 2x512Mb and 2x1Gb. Most 512Mb modules are singled sided, while the 1Gb module is just a double sided version.
In my opinion all Team Xtreem is definitaly worth buying, all kits (no matter which) perform extremly great.
The advantage of a kit like this one is that you can be sure of what you'll get.
I'm sure eventually they will get those ICs. But for DDR 800 (which I am looking for with FSB 400 OC) these would be nice.Quote:
Originally Posted by SMa
Hopefully the price is good.
So TeamUSoffice, are the 3-3-3-8 533MHz sets just low binned D9 MGH?
I just received my 4-4-4-10 DDR2-800 kit, I believe they are D9 GMH also...
A bit reluctant to tear the heatspreaders off just yet
yup, though i suspect there may be something similar to what happened to BH-5 going on.. single sided sticks tend to oc better on average :toast:Quote:
I think its a good thing, GMH and GKX are the exact same chip with different binning, and GMH costs a whole lot less. So xtreem with this high bin GMH might be able to offer it for a fair price while guranteeing performance on par with GKX.
D9gmh Ftw!
I'm not certain about their binning practices though:
A few weeks ago I did the whole 939-> conroe upgrade.
My TG Xtreem 667 3-3-3-8 runs 4-4-4-11 at DDR2-1004 stable (can't get much higher even at 5-5-5-16).
I just got some Xtreem 800 4-4-4-10 which won't run at DDR2-1000 it BSOD's at 4-4-4-10 and still occasionally randomly reboots at 5-5-5-16!
Both sets were D9GMH!
All 4gb of my 1gb modules clock better than the 512*2 pair I had :)Quote:
I corrupted c:\windows\system32\config\system just by using the 512*2s at the same speed as my 4gb! LOL!
Afireinside has tested 6*512 now, and his results really are not better than anyone else with decent 2gb kits and the same voltage.
Originally Posted by Phosphate
3-3-3-8 533MHz is NOT D9GMH..It's D9GCT
OPB
OTQuote:
Originally Posted by dinos22
you can be serious takeing it to 2.8v for ddr2. but you really want to kill these sticks so fast that is an extra volt not just a little extra but a whole lota extra juice so 2.5 is where i would stop upping the volts.
getting back On Topic
Team Group's ram really looks nice even with out the eye candy...all the other manufactures have them. Were just so used to seeing them that we ask that question.
The TG ram is getting really good timeings and especially for ddr2.. hell i have ddr400 that only does 3-4-4-8.
will we also have a follow up ram done by OPB like a signature series.
or l337 version of the ram
Also are any places offering pre order.
Still the same die altough D9GCT is worse than D9GMHQuote:
Originally Posted by TeamUSOffice
Passed 2 hours orthos large FFTs 800 3-3-3-8... still going on strong :D Im a happy camper. :) Maybe i have one set of these "golden" sticks.
Oh yeah i can do 4-4-3-8 atleast to that 1040 when my mobo/cpu craps out.(no orthos though because i couldn´t stable the rest of the system @ those speeds with this DFI. Only superpi1M for quick benching.)
my 2gig 667 3-4-4-8 also run 400 3-3-3-8 2.25v-2.3 and 1050 4-4-3-4
I'll try those sticks when they are in stock at Tankguys :)
well you don't run 24/7 with that much vdimm lol.....i'm talking max bench clocks which is what people do here.....actually 2.8 is conservative lolQuote:
Originally Posted by Mr_Slinky
Pricing for this memory will likely be in the ~$385 +/- $10. From what I'm hearing, it should be well worth it ;)
edit: damn good deal for what they are then. aren't other ddr2-800 cas3 2x1gb kits around... $450? time to check :D
i'll say. plus, i'm been running my team 2x512mb D9GMH sticks at ~2.6-2.8v.. basically since i got them?Quote:
exactly :DQuote:
I want a pair too!!...Quote:
Hee... :D
Perhaps you can PM TankGuys for details. I always keep them updated on pricing and ETA of TEAM XTREEM products.Quote:
WOW Best News FROM TEAMGROUP!.....
my 667 run 2.25 400 3.3.3.8 and 2.40v 430 3.3.3.8 with p5bdlx
4.4.4.10 2.4v 560 4.4.4.10.
New Best Choice from TeamGroup
GiGi77Italy
