yeah i've seen your posts on thatQuote:
Originally Posted by eva2000
2:3 works fine and would yield high RAM clocks at lower FSB
lower FSB will not hurt those runs i don't think as much as the high clocking 4-4-3-x ram would help the run :) :toast:
also unlike on phase change where you are working with constant cold temps so you have time so you can figure out 4:5 and 2:3 tweaks, on DI you only have a finite time to pull out the clocks until you run out of DI, so probably not much time to tweak for 4:5 or 2:3 :)
i'm sure kev,giorgio,KP and rest have had plenty of practice and different sticks lying around to try hehehQuote:
3 nice score, very congrats boys...:)
The work on his is very perfect...;)
Bye...
