so these will be am2
the articles from the_INQ are refering to socketF servers. look at the title of the PDF document on the screenshot.Quote:
Originally Posted by osiris999
but we don't know if they will be.
Regardless if it comes out in october or ends up being december. It means good things for the consumer, more price wars.
I can imagine someone or a group of folks at AMD that surf the forums and spend the day entertained at all the speculation over specs for chips and related hardware/software.
<<<<<<< grabs a bag of tortilla chips and salsa and some green tea and continues to read.
you will have quad core for am2 so dont worry.
Originally Posted by The Ghost
He got fed up with threads like these, seems like every amd or intel thread these days turns into a debate about something unrelated.
i thought that he had just got busy , but i see now that he has not posted for almost three monthsQuote:
yeah i think you should be able to find him at OCX... im not sure though.
Really . looking at it purely from the cost of sand,. Which is more expensive to produce . SOI sand . or Stresssed sand. Than lets look at wafer size . Intel has been at 300 for some time and AMD is struggling to get theirs mature.Quote:
Originally Posted by duploxxx
Intel is working on 450 wafers presently . But I don't think will see until 2010 or later.
Its all about choice you can buy a slower AMD cpu and save a few bucks . Or you can buy an Intel cpu for best performance . Bottom line its your choice . Intel makes higher margins than AMD thats the way it is thats the way it will remain. I personnally can't wait for the Dragon cpu's from China to catch up . Than the party shall really begin.
where did you get this at ? is it just something that you just made up ?Quote:
the reason why amd took so long to go to 300mm wafers was mostly due to the cost , amd lets intel go spin it's wheels , and then goes in for the stuff when it is proven , and getting cheaper , just like DDR2
and i thought that intel had to wait for some one to manufacture 450mm wafers , unless you think that intel actually builds the wafers ?Quote:
then they have to build the fab for 450mm wafers
450mm: not in this decade say executives
http://www.electronicsweekly.com/Art...executives.htm
Monday 17 July 2006
Now that 300mm technology is becoming mainstream, analysts and chipmakers are beginning to talk about 450mm wafers. But this time, it appears to be just talk.
Both Applied Materials and Novellus, two of the biggest makers of capital equipment for building wafers, say the option is not even on the foreseeable horizon. And while executives at both companies do not discount it could happen someday, that day is a long way off.
“Eventually, at the right time, there will be enough impetus for 450mm,” said Mike Splinter, president and CEO of Applied Materials. “But volumes have to grow significantly for there to be enough motivation. We’re nowhere near reaching the potential of 300mm.”
He noted that 300mm has anywhere between six and eight more generations of process nodes before it will be necessary to consider 450mm. “I don’t think in the next 10 years it’s viable.”
If true, this is a pretty lame reason to quit as he will get the same on any forum.Quote:
Originally Posted by Revv23
http://www.theinquirer.net/default.aspx?article=30179
http://www.fabtech.org/content/view/1665/
The well documented difficulties with the 300 mm transition have led some to question whether 300 mm will be the last wafer size — and yet the 2004 update of the ITRS calls for 450 mm wafer production in 2012. This article will discuss the results of simulation studies carried out on 450 mm wafer production costs vs. 300 mm wafer production costs.
I guess we have to wait till 2008 to see whose wheels are spinning when Intel goes back to Rambus for its memory solution. Iam am very sure none of us intel users would mine seeing intel using XDR ram rather than DDR3 . If Intel doesn't Back DDR3 . Lets see how fast it ramps. XDR has been out now for quit a while . So its mature enough and by the Time Intel uses it in the Nehalem package it will be extremely fast.
wel i know that yu do not want to match your first link with ymy link , because you provided a second link that agrees with my linkQuote:
Originally Posted by Turtle 1
thank you
450mm wafer adoption down to Applied Materials Print E-mail
Tuesday, 18 July 2006
SEMATECH maybe the industry consortia trusted with the task of producing the cost/business models for the possible wafer size migration after 300mm but it's plain to see that Intel Corp is the company most heavily behind the modelling work.
Though Intel may want to move to the 450mm wafer size ten years after the adoption of 300mm wafers, it's impossible to find any equipment company executive prepared to put any toes in the water and commit to the large scale expenditure to develop the processing tools to handle the larger wafers.
from your second source
it is more then 3 months , since the last time he posted over thereQuote:
I try to be opened minded. As I said I doubt 450mm be around by 2010 but if intel wants it I think they will get what they want . Break threws occur every day . Plus the fact that AM CEO is an x intel man does not hurt Intel position here.
why doesn't intel just shoot directly to xdr2 instead of just xdrQuote:
do you have anything good that intel has to say about xdr memory
here is the good stuff intel has to say about FBdimms
http://www.intel.com/cd/channel/rese...ors/250634.htm
Provides over 3 times higher memory throughput† allowing for superior application responsiveness
Enables increased capacity and speed to balance capabilities of dual core processors
Allows for Intel® I/O Acceleration Technology to more quickly access and process data
Performs reads and writes simultaneously; eliminating the previous read to write blocking latency
Supports a faster front side bus
i'm always interested in learning something new
Since this is all subjective anyway I used XDR only as an example. Since the Inquirer articles points to Rdimms and micro buffers. If this story has any merit to it . I am reasonabably sure it would be XDR2 were talking about.
Now my wife's brother inlaw told me that Intel may be looking to buy rambus befor the inquirer article came out. That got me excited. When we were discussing this issue on the phone I reminded him that it was he that told me that AMD was't buying ATI. Since he was the engineer on the R500's memory controller and had told the ATI he was leaving them to work for Intel . He said he was left out of the loop on that one. I can except that.
He also reminded me that Intel shopping for rambus was just skuttlebutt at the present time.
But it would be a huge slapp in the face to both AMD and ATI . Since the ATI memory controller uses some rambus tech . That does have a lincense agreement in place.
as big as intel is , it would have to jump thru a bunch of hoops to buy rambusQuote:
that would be like if intel wanted to buy amd , mission impossible
also would that not be a stop toward a monopoly?Quote:
Though if they are anything like M$ then I am sure they could get around it.
This is of course IF they were to try something like that.
Rambus with a market cap of only 1.7 billion would be an easy buy for Intel.
As for the monoply stuff still not following you on that. Intel would basicly only be buying the Rambus patients . I see no monoply here at all . Samsung and the rest of the dram makers would simply be paying intel for its royalties.
Please explain were there would be a monoply in this purchase. I see AMD buying ATI as being monoply . As it could easily put NV out of business or setting NV up as the source for the only gpu graphics card .
As has been stated in several articles Intel is going to build its own highend GPU . Which will more than likely be ondie . It will also probably be dual core,
At 45n there should be plenty of room on the die for 4 cpu's and a dual core gpu with point to point inter links.
I am sure AMD will do the same ATI. So were does this leave NV .
Looks like a monoply to me. It also looks like the people bidding up NV share prices are a bunch of retards.
I will buy the R600XF when its released even tho it will be an AMD release. AMD had nothing to do with its development. If they did I wouldn't buy. Its that simple. Now if AMD opens a new york foundry than I will buy their products but not until than.
Fact is in 3 years NV will be gone unless they buy a cpu company . Or maybe dragon cpu's out of china will buy them.
Nehalem is just under 2 years away. But we will have a lot more info by than
market cap means nothing on buying a companyQuote:
do you think that you could really buy intel for 106 billion ?
.Quote:
intel already owns a memory company , and when they buy rambus out , they buy more then just the patents , and this isn't going to bother amd , because just like amd uses alpha patents , they was bought and paid for , just like rambus patents , will be bought and paid for by amd , what do you think amd is paying 15 million a year for ?
intel already owns a memory company , amd does not own a chipset video card companyQuote:
intel has already tried to build a highend video card , it floppedQuote:
no one is putting nvidia out of business , if amd was to try and buy nvidia , that would fail because amd would be trying to form a monopoly
i think that you have to worry about intel getting to 45nm first , so far they have not shown that much with their 65nm cpu's
.Quote:
why are they retards ? with intel saying that they are not going to allow ati to have a intel license , that puts nvidia in demand
this where the problem is , there is talk that intel will not allow ati to make that chipsetQuote:
.Quote:
?NV wikk be strong in three years , they are not going away , they will still make video cards andchipsets for amd systems , amd is going to try and have ati build them a low power drawing chipset for amd's notebooks
why would dragon cpu buy nvidia out ? what use would nvidia have with dragon cpu ? dragon cpu is no competiton for either amd or intel
two years is a life time away in this businessQuote:
Umm now they do (see ATI-AMD merger)Quote:
R600Xf was in referance to a video card, Not a chipset. Intel owning a memory company means zero . Their are lots of Memory companies.
Yep intel did fail at their first stab at a Video card. But they own the rights to some interesting video tech now I believe Its called VR I should look but I believe thats correct.. They have also went out a gotten some pretty good engineers. Very good ones. Guys from NV and ATI and more are leaving the AMD/ATI ship for Intel . MEN are all about $$$$$$. They got almost all the engineers from that GPU maker that recently gave up the ship. Its name slips away from me at present.
As for the RD600 chipset Intel cannot stop ATI from selling that chipset. Intel can apply pressure on M/B makers not to produce it . As has been reported . But I doubt intel was pressuring any M/B makers from using it. More like they (M/B makers) See no future in that chipset other than DFI.
If Intel and AMD go ondie with GPU'S that will put NV out of business . I think most of us can see thats direction this multi- CPU on die is heading '
At 45n there will be plenty of room for for 4 cpu's and 2 gpu's on die.
I think your funny . Intels 65n cpu's not looking good . LOL . AMD is coming very soon with their 65n cpu's Well just have to wait a little longer to end that debate won't we. Your the first person ever I have heard say Intels 65n cpu's SUCK. Why's that?????
On licenseing its only a 5 year license after that period If its not renewed . A company can not use the the teck unless the license is renewed . Thats how it works.
Nehalem is less than 2 years away and K8L is a year away. AND Penryn 45n is 1 year 4 months away. I think Intel is in complete controll.
Now it would seem your saying AMD will beat Intel to 45n. LOL
Intel will beable to use ATI gpu's as long as they are in a pci-e card formate. and AMD'S R600 looks to be a NV killer. Intel is closer right now to having a unified Arch. Than NV. INTEL =VR
http://uk.theinquirer.net/?article=33661
I was meaning INTEL-Chip maker AMD -Chip Maker.
AMD = INTELs competition, yes there are nother CPU makers but these two being the big dogs, if INTEL were to but out AMD then there would be one Top Dog..............which would not be good.
Why are you discounting the Dragon Cpu from China. The Worlds largest Market in the worlds fastest growing econmy.
These guys in China are very smart and they are catching up fast. And the Godson 3 is said to be X86.
On July 28th, 2006, ¡°China Electronics Academy Computer and Application Project Session Science Reporting Conference¡± was held in Beijing. In the conference, academician 0f CAS, director of the Institute of Computing Technology Mr. Li Guojie declared a new production and said, ¡°The newest Godson CPU developed by our country has achieved the level of Pentium 4.¡± In the academic report of ¡°the computer technology in 21st century¡±, Mr. Li Guojie reported the newest progress of the development of Godson CPU. He pointed out that Godson 2E CPU was produced by 90 nano and the processing ability was similar to Pentium 4. The newest product will be released recently. He said, ¡°The comprehensive capability of Godson CPU developed by our country has reached the level of Pentium 4 and can satisfy the mainstream calculation demand. The mass production of Godson is being planned. If the plan is carried out, the annual production of Godson can exceed ten million.¡± Meanwhile, he expressed that Godson 3 would be the processor with 16 and more core. It will be used in the capability as well as high-capability server produced by ICT and Dawning jointly. The technology level of Godson 3 will catch up with the international level in the future.
China’s Emerging Microprocessors
Tom R. Halfhill - Senior Editor {07/25/2005}
Beyond the land of the rising sun is the rising Godson, a growing family of microprocessors designed and manufactured in China by Chinese engineers for the Chinese domestic market. Intended for low-cost desktop computers, servers, and embedded systems, these 32- and 64-bit chips are rapidly becoming as sophisticated as any designs in the world, falling short in performance only because Chinese fabrication technology lags behind the rest of the industry by two process generations.
Microprocessor Report briefly described the 32-bit Godson-1 in 2002, but few technical details have trickled out of China until now. (See MPR 12/2/02, “China Unveils MIPS-Like CPU.”) All Godson processors are designed by engineers at the Institute of Computing Technology (ICT), part of the Chinese Academy of Sciences in Beijing. In 2002, ICT and Chinese entrepreneurs founded a Beijing-based fabless semiconductor company, BLX IC Design Corporation Ltd., to bring Godson processors to market and support them with software-development tools and product-reference designs.
In December 2003, Advanced Micro Devices and BLX IC Design announced a relationship and opened the AMD/BLX Computing Client Development Center in Beijing. BLX IC Design is creating reference designs for thin clients and other computing products using AMD and BLX IC Design processors. The first two products are thin clients powered by AMD’s MIPS32-compatible Alchemy Au1500 processor and BLX IC Design’s Godson-1. The creators of the Godson-1 say its architecture is “MIPS-like”—a description that annoys MIPS Technologies, which doesn’t authorize the Godson architecture or license any intellectual property to ICT or BLX IC Design. AMD, which is a MIPS licensee, says it encourages BLX IC Design and MIPS to resolve their licensing issues.
This spring, ICT introduced the Godson-2, another “MIPS-like” processor. Considerably more advanced than the Godson-1, it has a 64-bit architecture, four-way superscalar pipelines, dynamic branch prediction, out-of-order execution, and other powerful features. China’s Semiconductor Manufacturing International Corporation (SMIC) fabricates Godson-2 chips in a 0.18-micron CMOS process, and ICT is porting the design to a 0.13-micron process. ICT is also beginning work on the next-generation Godson-3, which may sprout multiple processor cores and hardware-assisted simultaneous multithreading.
It’s clear that China wants to produce general-purpose microprocessors as advanced as any in the world. The Godson family (also known as Dragon) is only one fruit of China’s National 863 Program, a government-funded research and development project to create homegrown technology for Chinese high-tech industries. For now, Godson processors are solely for China’s domestic market, but exports to world markets are possible in the future.
In June, MPR interviewed Godson’s chief architect, Weiwu Hu, a professor at ICT in Beijing. Weiwu described the Godson-1 and Godson-2 in unprecedented detail and revealed some of his ambitions for the Godson-3. In addition, Weiwu provided an English-language white paper on the Godson-2 microarchitecture.
After analyzing this information, MPR believes the Chinese already are capable of designing world-class microprocessors, assuming they have access to world-class fabrication technology. Although Chinese fabs are about two process generations behind the curve, China’s technology is rapidly accelerating. China could also outsource some chip manufacturing to foreign foundries—perhaps even to crosstown rivals on the opposite side of the Taiwan Strait. (Irony knows no borders.)
So their you have AMD which has no us fabs . Is helping China's government. I up this is a case of the DOG biteing tha hand that feeds it.
