Updated. :cool:
Updated. :cool:
I'm not sure if this is the MAXXX, or if it can be done on less voltage, but I'm not going to mess with it, as it's very stable...
- Intel 975x
- Team Xtreem 2gb (2x1gb) DDR2-667 3-4-4-8 (TXDD2048M667HC3DC)
- 2gb (2x1gb)
- DDR2-667 , 3-4-4-8 , 1.8v
- DDR2-1000 , 4-4-4-8 , 2.2v
- Micron D9GMH
- http://valid.x86-secret.com/show_oc?id=122101
- I hope this is sufficient: http://img114.imageshack.us/img114/6845/e662ju2.jpg (sorry, I'll run 32m later if necessary...)
- AndrewZorn
Need a super pi 32m, despite prime probably being a better test of stability, it's the rules... ;)
I'll add it as it is for now. Thanks for the submission brother. :)
| 2x1GB DDR2 Category:
Corsair | Chosen. | Samsung 200MHz DDR2 ECC | DDR2-400, 3-3-3-8, 1.8v | "M3 91T2953BG0-CCC" ? | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-800, 5-5-5-15, 2.2v
http://img116.imageshack.us/img116/9012/eccuj2.jpg
These are my 2x1Gb, 100% overclocked ECC Samsung DDR2-400@800 (they actually do 840MHz before everything hangs - SuperPi 1M @ 820MHz+ ) and still without heatspreaders... :eek:
anybody care to post some 4x512 results? pretty please?
Database updated, also the guidelines have been altered a bit to be more flexible and hopefully more accomdating regarding the screenshots needed and such.
@BlaqMale: This db does not support any 512MB dimm results.
how long of a p95/sp2004 test though, and which one ;)Quote:
Originally Posted by EnJoY
Large ftt's, 5+ hours. Edited. ;)
Thanks ozzi.
heh, sorry if my primeness made you want to change the rules. ive not quite had a good chance to run dual 32ms.
that being said, if i were to test my 1000mhz 4-4-3-4 overnight, would you rather have a long orthos, or dual 32m, or no preference?
PS
i keep seeing the blue names and i think they are links
how fancy would it be to have the name hyperlink to the post with the screenshot, extended info, etc
itd only be a lot of work if you waited until you had 200 entries to think about whether or not to do it
great clock and timings but no place for 2x512 :p:Quote:
Originally Posted by Unseen
I hope the wait was worth it...
Now at 4-4-3-4[-2]
http://valid.x86-secret.com/show_oc.php?id=123613
http://img389.imageshack.us/img389/2...lityve0.th.jpg
Oh shιt... I didnt saw it... I will delete my post.Quote:
Originally Posted by AndrewZorn
sorry for that.:rolleyes:
4X1Gb
Corsair 6400C3 and Team XG 8000 :banana::banana::banana::banana:tail with 2.3V in bios...
http://img58.imageshack.us/img58/763...shot003iw6.jpg
2x1GB DDR2 Category
Intel
Adata | kiwi | Extreme Edition DDR2 1000+ EPP | DDR2-1000, 5-5-5-15, 2.2v | Micron D9... | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-1050, 4-4-3-12, 2.6V
DB Updated, thanks for the submissions guys, check out that brand variety! :)
Dumo, could you please present this submission to me in a more informative fashion? I need two instances of superpi 32m or prime, a cpu-z validation, the stock timings/speeds/volts of each stick, and the precise model names. Also, what chips they are using would be nice... :rolleyes:Quote:
Originally Posted by Dumo
I look forward to this info so that I may add you to the ranks. :)
Intel
Corsair | Xevipiu | TWIN2X2048-6400C3 | DDR2-800, 3-4-3-9, 2.2v | Micron D9GKX | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-830, 3-3-3-1, 2.13v
2 x 1Gb Corsair 6400C4 @ DDR2-850, 4-4-4-12, 2.2v
My spec is as the sinature below. This setup is stable for over 5 hours on Orthos, but no screen shot as yet. Used as my 24/7 setup.
Full load temp on Orthos was 67 degrees C.
http://valid.x86-secret.com/show_oc?id=124326
[IMG]http://img85.imageshack.us/img85/691...izedwv6.th.jpg[/IMG]
^ Both added, thanks. :)
Just looking at the results posted for this database and my last one, this is nearly all Intel and the other was nearly all AMD. My databases show the brand trends of their generations. :p:
http://valid.x86-secret.com/show_oc?id=125272
http://www.iamxtreme.net/ram/gskill/8002gbhz/1160.JPG
Intel
2GB (1GB*2)
G.SKILL | guess2098 / Denny | F2-6400PHU2-2GBHZ | DDR2-800, 4-4-4-12, 2.2v | Micron D9GMH | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-1160, 4-4-4-5, 2.45v
Excellent Denny, thanks so much for the post and excellent work on the submission, you followed the rules precisely. :D
Intel
Crucial | Xevipiu | Ballistix6400 | DDR2-800, 4-4-4-12, 2.2v | Micron D9GMH | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-760, 3-3-3-1, 2.1v
Corsair | Xevipiu | TWIN2X2048-6400C3 | DDR2-800, 3-4-3-9, 2.2v | Micron D9GKX | CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-837, 3-3-3-1, 2.13v
Updated, sorry for the wait guys, been busy. ;)
Intel
Mushkin | Kunaak | mushkin eXtreme Performance 2GB-DDR2 800 | DDR2-800, 4-4-3-9, 2.0v | Micron D9GMH| CPU-Z Validated! & SuperPi 32M Stable! @ DDR2-1180, 5-4-4-10, 2.8v
Updated. Thanks Kunaak. :)
Ha, I totally forgot to submit my only saved result from 6400HZ, after which it got messed up a bit :(
Come on, do I have to have 2 best results on a list? :lol: :p: Let's get this database going, people :)
G.Skill | bachus_anonym | F2-6400PHU2-2GBHZ | DDR2-800, 4-4-4-12, 2.0v | Micron D9GMH | CPU-Z Validated @ 1242! & SuperPi 32M Stable! (photos) @ DDR2-1224, 4-4-4-8, 2.75v
