i dont have reboots on my dq6.overclocked 36%.But...i have Presler and Kingston hyperX pc 7200 memory..maybe its because of memory or something...so far so good...
Flashing to BIOS F4D seems to have fixed the clock control reseting and reboot loops. I can also boot no problem with >400 FSB. I cant say those problems will not return, but it seems better atm.
GAM, sorry I meant to say that vDimm was also set to normal.
I didn't know that 1.9V was preferred with the EM2s. Even at 800MHz? Anyways, I didn't have any issues with the XP2s. My problem with the EM2 could be because I overvolted them, or the BIOS did if vDIMM set to Normal.
There are so many variables!
Running at 8x375 FSB has been rock solid for me - dual Prime stable for 62 hours even when the heatsink wasn't making proper contact with the center of the CPU! On Tuesday I ran dual Prime for 16 hours just for the heck of it while running World Community Grid at the same time with no problems. RAM timings at 4-4-4-12 with these XP2s.
DS3 F5 (Final) + Presler @ 300FSB/3.6GHz (that's not much of an oc, considering the stock freq is 3.46GHz @ 266FSB)...
I'm getting random OC reset as well. It happens once in a blue moon, but when it does happen, the "Host Clock Control" will reset to Disabled and it'll go back to the default clock speed. It'll only happen when I've shut it down for a day or so and started it again. It's never happened no matter how many times I restarted the system, even if I turn it off, press the power button again to start it.
I've tested with both MemTest, Orthos and 3dmark05 over night and there seems to be no problem whatsoever. Been using this for 3 weeks, even completing Need for Speed most wanted without any problems. The only 2 problems I've seen so far are:
1) OC random resets
2) SATA drive random boot disk failure
These problems only occur once in a while. Does Gigabyte know these problems yet?
According to this, http://www.valueram.com/datasheets/KHX7200D2_1G.pdf, the SPD of your RAM is 1.8v. Now I don't really know what I am talking about here, but this is an indication to me that the RAM is 1.8v.Quote:
Originally Posted by DARK SIDE
It would be nice if someone who 'knows' these things could shed some light on the subject.
(I wish I had my board back so could be testing all this.:( )
Re EM2 1.9v. Refer to http://www.mushkin.com/doc/products/...ail.asp?id=373. Whereas, XP2 indicates a range of 1.9-2.1v. Refer to http://www.mushkin.com/doc/products/...ail.asp?id=350Quote:
Originally Posted by Rectal Prolapse
I was expecting your experiences to be the other way around i.e., EM2 no resets, XP2 resets.
Good news. Let us know if this changes.Quote:
Originally Posted by Eldonko
Have you tried F4 final yet? er... and any of the later betas?
As you know, 'Normal' vCore auto sets itself where ever it thinks is best. Probably better to set it yourself even at stock voltage if that works for you. 'Normal' mightn't be giving your CPU enough. I've had spontaneous reboots from Windows with insufficient vCore. (Don't mean to beat a dead horse ;) )Quote:
Originally Posted by CrazyJohn
Sorry, I can't offer any other suggestions in this case.
'..."Host Clock Control" will reset to Disabled and it'll go back to the default clock speed. It'll only happen when I've shut it down for a day or so and started it again. ...'Quote:
Originally Posted by ZachSaw
I've seen this circumstance a few times too. Maybe these boards are a bit like car engines, they don't like 'cold starts'. :D
ZachSaw, what RAM?
Corsair ValueSelect 667 @ 800 :DQuote:
Originally Posted by GAM
Not the ram though, since I've had memtest running on it for over 8 hours...
Someone should inform Gigabyte...
try with lower multi on CPU and rise FSB to 420 + and see the reboots :D
you dont have problems cause you dont use high FSBs ;)
there is so many threads of gigabyte mobos that we all already know that all models of gigabyte have reboot problems , sometimes boot with XX settings and next minute dont bot with same settings , ........ and other issues .
GUYS its NORMAL on all gigabyte mobos reboots, and other strange things , didnt you guys realised that yet???
regards
Everything is working fine with F4D so I'm sticking with it. :)Quote:
Furry muff ;)Quote:
100th post! :woot:
I'd recommend the F4d BIOS for the DQ6 too. I've never experienced any random resets (except when over 460 FSB, which isn't surprising), or boot loops.
My HZ works fine at 1.8v, in fact more vdimm seems to hinder overclocking.
No dude....it is 2.0V to 2.2V.That's kingston hyperX ddr2 pc 7200 memory(900mhz factory optimal speed)...i advise you to avoid this RAM because of "elpida" chips inside, who are not good for overclock(sadly i have 2 giga of this ram)...Kingston pc 8500 hyperX(on 1066mhz) have "micron" chips that overclock very good....Quote:
LOwer multi on Presler 920?:eek:Quote:
Originally Posted by mascaras
Btw.for me its normal for DQ6 to work fine with no reboots..:D...but i dont like strong overclock..maybe she will go crazy with high vcore,fsb or other overclocking stuff..
Spec as per sig, F6a BIOS
random reboots over 400mhz on the 9x multi (was unstable but bootable with F5)
Exactly what RAM are you using (model nos.)?Quote:
Kingston HyperX Dual Channel DDR2 (PC2-7200): http://www.valueram.com/datasheets/KHX7200D2K2_1G.pdf ?
1.8V for the HZ is cool for POSTing and making voltage changes...but has anyone tried to boot in Windows with 1.8V and 800Mhz?
Cause G.SKILL say it needs 2.0-2.1V for 800MHz, i run 2.2V to run at 933Mhz...pretty sure it good upto 1000MHz at 2.2V.
this one(2 giga i have):Quote:
PS.folks from kingston email me and told me that i can run this memory on 2.2V with no fear.
This pdf applies to your RAM: Kingston HyperX Dual Channel DDR2 (PC2-7200): http://www.valueram.com/datasheets/KHX7200D2K2_1G.pdfQuote:
It suggests to me that the 'default' voltage is still 1.8v (not referring to optimum, ideal, required, etc, just 'default').
Sticker on my ram says 2.0V..not 1.8V;)Quote:
I have dq6 mobo with c1 rev. of chipset...couple of days and e6400 will arrive...looks like c1 rev sucks for overclock...i think c2 is not in the market...
ps. cpu-z ver.1.36 have data for rev of this chip...
I am not doubting you, just trying to understand the difference between the various references to RAM voltages. Consider the subject dropped ;)Quote:
[edit: wrong board. sorry - 8i945pro]
Had... Rev. A1 (according to this old screenshot from Everest):
http://www.xtremesystems.org/forums/...0&d=1156791997
Board is getting 'repaired'-broken CPU socket pin, apparently. Getting very impatient for its return. 2weeks+. :( Apologies for not being able to contribute testing/info at the moment.
Best 'dual-prime stable' OC, before failure, as per sig. 'Decommissioned'.
It's ok;) .You are right...kingston forgot to put the range of voltage in data sheat from 1.8 to 2.2V:) .Thats the only thing here...Quote:
good luck with the board...;)
Oops. Sorry, screen shot and revision detail is for a different board (GA8i945Pro). Decommission sig details still apply though.Quote:
