Thanks for the info DVL73, think i maybe contacting you if i have any problems with setting the tbalancer up :)
Basically for the £40 I spent I got the following:
1x external USB cable
1x internal USB cable
1x Control unit (UV orange plastic)
1x analogue sensor hub
4x thin foil temperature sensors
7x fan -> fan signal cables
Mounting material
CD With software
4x Attenuators (allows 2 fans to connect to each fan port, so max of 8 fans)
He also threw in a Water Probe.
I added all that lot up on the Kustom Pcs website and it came to £90 excl delivery :eek: thus I was more than happy to pay the £40 inc del :D
In your opinion is it really necessary to have the MiniNG, and I assume I could control 3 fans with it using the atenuators?
