Originally Posted by Tamerlane
Awesome results. What temps (idle, load) do you get with which monitoring software on the 3.6Ghz @ 1.475 setup?
I am also interested in a *quiet* overclocked e6600 and am trying to decide between the P5W and P5B, so your results using the same retail chip (week 23 or 27) will be very useful. Especially if you have decided on a safe max temperature range for quiet cooling, and then you compare actual performance (Pi or 3dmark) of the P5W and P5B at the max o/c each board can reach while staying within your safe temp range.
I haven't seen anyone do this on the two m/b's. Previous comparisons of clock for clock performance, max cpu speeds of engineering samples, etc. are interesting but what many people want to know today when choosing motherboards is the ultimate performance difference at a specific retail CPU temp range that they are comfortable with.
