Mobo: DS3 w/ F4 bios
Mem: G.Skill PC6400 2x512mb micron D9 chips???
Max: 550 4-4-4-8 2.1vdimm
Boot: no issues
Boot: no issues
Proc: E6300
Mobo: DS3 with F4 bios
Mem: A-DATA Vitesta 2x1024MB PC4200 DDR2-533
Max: 266 (stock :( )
an update
TYPE: 2x 1GB Corsair XMS2 PC2 6400 5-5-5-12
MAX: 500MHz 5-5-5-15 2.0v
BOOT?: Boots fine with F3 and F4 bios on DS3
DS3 BIOS F4E
Corsair TWIN2X2048-6400 5-5-5-12
at DDR 428 1.9v
MAX: ?
booted at 1.8 with F1 BIOS even though it's rated for 1.9 :)
Processor: E6300Quote:
Originally Posted by crimson117
Motherboard: DS3 with F3 bios
Memory: A-DATA Vitesta 2x1024MB PC4200 DDR2-533
Max: 400 2.1v with 4-5-5-? timings
Havn't tried tweaking it in a while, as my computer is up in my apartment with my roommate and I'm in my girlfriend's apartment downstairs. :) I've done this with many Memtest runs and so far have not tried pumping more volts into it. We'll see what I can do when I get my computer back in a week or so.
bump :)
DS3 E6300 450x7 4-4-4-12 2x512m pc800 cls 5 +0.2v
Can do more have run 500 1:1 with lower timings but have to play with timings to see if it pays off. Not bad 110E kit :)
So what is the consensus on the best 2 GB kits for the DS3? I still have my celeron running in mine with OCZ 1 GB platinums (4-5-4-15).
I want to step up to either the e6300 or e6400.
It looks like the corsair XMS Pc2-6400s are doing pretty well, but lately I'm seeing these Team Xtreme 533 MHz sticks too ($208).
OCZ plat ram 2gig (2x1gb) 5-5-5-15 , 2.1v running 3 days no problems. Passed 18 hour prime & memtest. found out my problem isn't ram but the cpu voltage.
bump
Btw...G.SKILL have kindly (or are) sending me a replacement HZ kit as my ZX kit kinda sucked. So i'll be testing these babies by the end of the week.
Feels good to get a replecement that is better then what i sent.
good luck with those Richard. you wont get over 950mhz with them
the DS3/DQ6 wont run the HZ's over 950mhz. this model of Micron D9 kit doesnt agree with the DS3/DQ6
I presume you guys are all testing your memory by dropping your FSB and using a 2.5/3x multiplier? It's definitely the chipset holding it back at <500MHz (DQ6) for me.
GSKILL
F2-6400PHU2-2GBHZ
Boots at default voltages. even at DDR800
Will not go past 950mhz DRam as this micron D9 has issues with the gigabyte boards.
F2-6400PHU2-2GBZX (which i see is no longer available)
will not boot unless you swap memory and raise the voltage to 2.2v
unable to go past 950mhz because of gigabyte bug.
Proc: E6400
MB: DQ6 w/ F3
TYPE: 2 x 1G Mushkin XP2-8000 Redline
MAX: 502 3-4-3-10 dual 32M 2.2v (will test more vdimm when I get time)
BOOT?: booted first power up of the board w/ both sticks
COMMENT: Dont see any issues w/ this mem and DQ6.
you post this 950mhz limit in just about every thread on this forum. Have you tried the RAM in another board and proven it goes higher?Quote:
Originally Posted by Lestat
Team 667 @ 930 4-4-3-8 v2.1
6300 @ 3.2ish still testing..
I think this setup has killed one of my 250G in raid 0 :(
Thats gonna suck bigtime if they did die..
I have GOOD news...G.SKILL sent my 0627 HZ kit today. I'm using a DQ6 with F4d beta bios. IT POSTS!!!!!!!!!!
WOO HOO!...you don't know how great it is that this memory POSTs with default 1.8V, with my ZX kit i had to swap the modules out with some cheesy Nanya module so as i could manually set the voltage to 2.2V...otherwise the ZX kit would not POST.
This HZ kit will and does POST with default 1.8V, i am testing the memory now...even if it won't go past 950MHz or even if i can't get my FSB to 400MHz...at least one big problem has been solved.
BTW...the memory runs 4-4-4-12 by SPD, it's set to Auto and run SPD in bios:
http://valid.x86-secret.com/show_oc?id=118914
You have missed a very important factor : the FSB!!.
on my DS3 the FSB seems to have quite a import on how high the Ram can clock., e.g.: when my e6300 is running at 400*7, I can use 2.5 divider, which means the 2*1G gskill hz is running at 1000 5-5-5-15 2.1v.
but if I use 2 divider for the ram, the even if the CPU runs at 6*480, the system is not stable (here the ram only runs at 960).
Originally Posted by CrazyJohn
my gskill 2gb hz can easily go to 1000mhz if the cpu runs at 400*7. (e6300, using 2.5 memory divider).
will post some screenshots tonight
some ppl from coolaler forum have reported that if using the 2*512m hz kit, they can run higher...
it is the board that wont let it go over 950, hes not the only one having the problem, others are having the same problem and so am i.Quote:
Originally Posted by BottomsUp
I'll ask again. Have you proven your set of RAM will clock higher on another board? It could be that not all these G.Skill sets are as great as we think they are.Quote:
Originally Posted by johnsally
All for those who have problems with 667Mhz rams (like BSODS, errors on memtest, etc), flash your BIOS to the F5 Final, that fixed all memory issues for me.
http://valid.x86-secret.com/show_oc?id=119026
I'm Orthos Prime stable now for 6 hours and 4 mins.
OK!...like i know if crap compared to the guys doing 3.4Ghz or more, but i have TRIED to get this board to POST at 400MHz FSB...just will not work.
