Originally Posted by eva2000
haven't measured via dmm only software heh but i believe the droop is correct
3.6ghz out of the box was easy as pie hehe
not sure about VRM cooling i have the heatpipe on but reapplied TIM on it and have removed those covers as i stated above
corrected typo SATA1 hehe, 9x440fsb isn't stable going to drop multipler to find the max fsb.. i have timings manually enabled never SPD with no probs
1.65v MCH i would consider safe if you have the cooling i'd probably change the stock NB heatsink if you want to run it 24/7 - i'm going to use Thermaltake Extreme Spirit II NB heatsink since i'll take it off my Bad axe hehe
re-read 1st post stock heatpipes with covers off, reapplied TIM and fan over them.. haven't tried 4:5 yet i've only had this P5W DH for less than 48-72hrs need time to test hehe
thanks mate... :D
i had to raise my MCH from 1.55v to 1.65v to get 9x400fsb = 3600mhz at 1.376v stable as i reported in 1st post ;) at 1.55v it will error out in stressprime after a few minutes
as to questions of where my ES came from, i could tell you but i'd then have to kill ya :p: LOL
more results coming soon :D
