Largesystemcach is not current control set, keep that in mind :)
But, decimal and 4096, that'll do :) - But with SP2 I belive auto detect works quite well..
Ah tks:)Quote:
Originally Posted by M.Beier
EDIT:D
oh thatQuote:
i actually tested that but gave up after seeing some :banana::banana::banana::banana: results with initial tests...............LOL guess which core i selected heheheh 0 :slap:
Finally I've broken the 13" aircooled...high v-core just for be sure to close. (24C ambient, CPU @ 41C IDLE)
http://img382.imageshack.us/img382/1891/dscf1353qm9.jpg
http://img145.imageshack.us/img145/5697/12921ou8.jpg
Now go for 11 sec ;)
Just playin' with ya :) - Took us hours too hit 11.9xxx - however, hopefully gonna hunt the 9.xxx sec on E6600 later this holiday.. - You can do that as well, but, 10.xxx + cascade might be more realistic..
One more thing, damnit, you pushed my great old X850XT + 3700+ 01SE run out of top10 at tweak.dk (40K run ;) )
I'm @ 11.1 but under DICE:D ...ok, was a bad Dice run... low FSB, low ram freq. and bad timings, next run under Cascade I want 10.5 1M:DQuote:
Sorry for tweak.dk:p:
Great :(
I had a 477*9 run, but couldnt get 1:1 due a mobobug :( (fixed with newer bios) futher... I'd been testing my mem on AOpen i975Xa-YDG, so I didnt thought they worked at lower than 4-3-2-4, they work at 3-2-2-4 ;) - So basicly, mem settings were :banana::banana::banana::banana:ed, however we used a great amount of time tweaking the sucker to hit the 11s level (especially since the danish record at that time was 12.8xxsec :)) )
M.Beier
Is that B2?
Yeah, didnt wanna give the cash for an ES :)Quote:
Originally Posted by kiwi
@nachty: have you tried with trp of 3 instead of 4 ? There isnt much difference between 4 in terms of clocking and it performs a lil better... ;) Yesterday i was playing with 8500 and ballistix pc6400 and got over 540 4-4-3 with the ballistix. :) (BTW the best i did was 595 5-5-4-9 with 'em )
Regards! :toast:
Don't try...I will try today:toast:Quote:
Originally Posted by ^don.k's^
Many tks...
Go UP:eek:
The 19° ambient help :D
Look @ the 35C idle temp:woot: 49/50 full load
First run over 4GHz without real time and Explore opened:
http://img176.imageshack.us/img176/3898/4ghzxm0.jpg
Don't like the final time and I re-run @ 4GHz:)
Alittle bit better.
http://img245.imageshack.us/img245/8936/12765pj6.jpg
Mine took a long time to finish 2X32M...Prepare breakfast, make coffee and its still looping:)
Vcore @ 1.48 with TT big Thypoon..
http://img180.imageshack.us/img180/4...shot219za2.jpg
Heres 4G 1M@ 1.5Vcore...
http://img177.imageshack.us/img177/1...shot224gc9.jpg
Wow!!!:slobber:
Step 5 need lower v-core right?
Beautiful chip.
Actually this is my best 1M aircooled:
http://img132.imageshack.us/img132/2393/12734yl9.jpg
Chipset cooling will help too..
http://img219.imageshack.us/img219/7...shot226xu1.jpg
Yes, I'm waiting to put my new WB on chipset too:)Quote:
Originally Posted by Dumo
http://img244.imageshack.us/img244/533/dscf1347bd9.jpg
Fast 32M with high mem timings:
http://img98.imageshack.us/img98/5818/32m1312gp6.jpg
Probably i'm missing something.. But, why do you have PCI-E ratio at 80 instead of 100Mhz? :stick:
hehe, Clock Gen bug.Quote:
Originally Posted by GordonFreemanLP
From Bios it's set to 101:)
Here a Test with a ASUS P5b Dlx WiFi Bios 0507
http://s2.bilder-hosting.de/img/6WWC9.jpg
JumperFree Config
AI = Manual
CPU Freq =500
DRAM Freq=DDR2-1000
PCI Express Freq=100
PCI Clock Sync Mode 33.33
Spread Spectrum=Deaktiviert
MemVolt=2.45
CPU Vcore=1,675
FSB Termination Volt=1.45
NB Vcore=1.65
SB Vcore=1.7
ICH Chipset Volt=1.215
Memory :
4
4
3
4
6
42
10
10
10
10
Auto
Wow, 32M @ 4GHz it's great.
What cooling on the cpu?
@nachthymnen
Sorry i forgot this to Post !!
Is a Single Stage Made by Ice-Man from Austria !!
Regards
NP;)Quote:
Originally Posted by splmann
Have you try XP x64?
For 32M runs it's very good!
no but i can try but i have only a old beta from XP x64
Regards
In 32M rulez!
Other UP full air:
http://img228.imageshack.us/img228/4066/2m311sw8.jpg
http://img228.imageshack.us/img228/1278/32m1308dl6.jpg
