Originally Posted by don_vercetti
I don't believe that's entirely true. Based on two things. Number one, the fact that when you lower the voltage, less wattage is consumed. As you no doubt know, Wattage = Volts X Amps. So evidently, as the voltage is lowered the current stays the same, rather than rising.
Two, when you overvolt, the current to the CPU doesnt drop does it. It stays the same (i think), otherwise we'd find the CPU running colder when we overvolt because if as you say they are inversely proportional, then that would hold true. Because it is certainly current that causes heat rather than voltage, hence why Power lines run 10,000v through them.
I imagine your thinking of what happens with a coil transformer. Lowers the current by raising the voltage, and vice versa.
