wait for nf590
wait for nf590
Sierra , what is with the 3.1v in cpuz?
CPU-Z does not read Kentsfield VCore correctly. Actual voltage is about half that much.
I will probably test with Kentsfield for the next week, and then Conroe. Not really interested in maximum FSB. Having multipliers above 10 makes that unnecessary. So far, this board looks like a keeper.
To bad not all of use have the cash to have that multiplier up to 10. :p:Quote:
Originally Posted by sierra_bound
I have not used my Conroe 6600 in this board yet. My guess is I will have only the 6-9 multipliers available. Kentsfield is basically like an Extreme Edition processor. With the right BIOS, you have a fully unlocked CPU.
Ok, i've now officially gotten mad enough at this Abit AB9 Pro that i just pulled the trigger on the Asus P5WDG2-WS Professional from eWiz for twice as much as i paid for this Abit board. Hopefully it will be actually worth it. I guess we'll see. The P5WDG2-WS Pro is $299 @ eWiz through Froogle.
wow you have to click through froogle's link to get the low priceQuote:
Originally Posted by burningrave101
that's pretty low of them
They do that through Froogle, Pricegrabber, and Pricewatch to get more hits from people doing a search for lowest price. If the person is already on eWiz.com then they figure that person will probably pay more not knowing to search for a lower price. It's pretty smart actually and i like it because i know to search and i get stuff cheaper :).Quote:
Originally Posted by Ender17
BTW, PCI-X is backwards comptabible with PCI hardware isn't it? That means i can just stick a PCI device like a sound card or TV tuner in one of the PCI-X slots?
Yes, PCI-X is backwards compatible. Of course, you won't get the same speed as you would with a PCI-X card.
I've always been looking for an excuse to buy some Seagate Cheetah's. This board gives me that excuse.:D
Well i was just wondering so that i would know whether or not i could use those PCI-X slots for anything. I guess now i'll be able to install my X-Fi, 56k modem, TV tuner, ect.Quote:
Let me qualify what I said. It should be backwards compatible. PCI-X is just an enhanced version of PCI. I will test it this weekend to verify. The board also has a set of jumpers to maximize the PCI-X frequency.
http://usa.asus.com/products4.aspx?l...89&modelmenu=1Quote:
PCI-X Architecture
PCI-X, the new and improved version of the previous PCI, offers faster data transfers and enhanced system reliability with ECC automatic single-bit error recovery and double-bit error detection. PCI-X enables users to keep pace with upcoming advances in high-bandwidth, business-critical applications such as Fiber Channel, RAID, InfiniBrand™ Architecture and iSCSI. It is backwards compatible with PCI-based hardware and software.
Originally Posted by Natalia
WS non pro does not support conroe.
Only Pro supports conroe.
4.4ghz 965 @ 32m = 3.9ghz 975 @ 32m
Just another clarifacation on pci-x, while is is backwards compatible you may run into problems with a pci and pcix card on the same bus.
I guess it's a good thing i'm not likely to have any PCI-X devices :D. I mean seriously, outside of a RAID controller card what else would i even consider for a PCI-X device?Quote:
Originally Posted by Torphoto
Firewire 800 card?Quote:
More tests with Kentsfield
http://img126.imageshack.us/img126/3...0043400as5.jpg
http://img231.imageshack.us/img231/5...nch3767eq0.jpg
http://img244.imageshack.us/img244/7552/3831ct9.jpg
This board seems to have less Vdroop than some of the other Asus mobos, which of course is good. Asus Probe reads temps a little high. But other than that, the board is solid.
All the important ratios work on this board - 1:1, 4:5, 2:3. There's also 4:3 and a couple others.
4:5
http://img84.imageshack.us/img84/7624/376745zv1.jpg
2:3
http://img149.imageshack.us/img149/8950/381023rh0.jpg
Thanks alot sierra. Looks like I maybe getting one of these if the p5w64 isn't out in 2 weeks.
Really? That's awesome. The 4:3 ratio will be very beneficial to me with an E6300. My OCZ PC2-6400 Platinum Rev2 may crap out at 1:1 before i reach the limit of my CPU at 1:1.Quote:
Has anyone done any testing to see what the max FSB they can get with this board on a lower multiplier like 7x?
AndreYang did 473FSB with a retail E6300.
http://www.xtremesystems.org/forums/...d.php?t=110126
I will test for maximum FSB when I switch to Conroe, which may not be for another week or so. Kentsfield is not a high FSB processor. What it offers is awe-inspiring rendering power.
The P5WDG2 WS Pro is a major improvement over the P5W DH Deluxe, IMO. The only ratios that worked well on the P5W DH were 4:3 and 1:1. The P5B Deluxe does great with 2:3, but not as good with 4:5.
I'm starting to get the itch again to buy this board thanks to you guys.
After further testing, I have to conclude the 4:5 ratio on this board is not as good as I first thought. It's about on a par with the P5B Deluxe. It's usable, but not for DDR2-1000 speeds. 2:3 is good for DDR2-1000+. This board almost feels like a cross between the P5W DH and the P5B Dlx.
All the results I've been posting are with air cooling (Tuniq Tower 120).
http://img.photobucket.com/albums/v3...32M37672-3.jpg
Wow. Wait for the nforce 590.
Every Intel board using an Nvidia chipset has been a dud up until now. I think more people are going to be waiting for RD600 than they are for Nvidia 590.
