The july 24th drivers from windows update still have the performance issue.Quote:
Originally Posted by MacClipper
Jeff
Jeff
Check the burst rate with Nero CDSpeed (freeware, just google). If it is in proper DMA mode, this is what you should get ~25MB/s,
http://img187.imageshack.us/img187/9...rstratepg8.png
Showed 28mb for me.
Jeff
Updates on this issue?
Solution: Deinstall the JMicron driver and use the standard Windows IDE-driver, while setting the JMicron to IDE in the BIOS, right?
i got 41 mb/s....
Hey all, I'm having this same problem. It's stuck in PIO mode. I never loaded any JMicron crap drivers, because my 2 SATA HDDs are on the Intel Matrix.
Any idears?
Nevermind - fixed it. :)
Can you post how you did it? Becuase i'm still having the dad-gum problem.Quote:
Originally Posted by Brahmzy
And, to anyone - does the IDE->Sata adapter work with DVD-R/W drives?
Stick with windows driver they work
I had the same issue with my P5B Dlx, E6600 and Samsung SH-W162Z DVD/RW drives.
Uninstalled the JMicron Raid Tool and the issue is gone now.
Burst rate showed 28mb/s as well.
