Soz about the lack of updates. Been busy with review and stuff.
I have some new RAM and a new chipset cooler but I also managed to break a CCFL
Awaiting stock as AC Ryan is the only make I'll have
I'm moving soon so hopefully I'll have some time to get some work done then
Very Neat Setup. Have Fun.
nice case i like!! and i like your WC
Thanks lads. I'm still not finished I'm afraid!
Moving flat soon and updates will be forthcoming.
Should have an Abit AW9D, Mushkin HP2 6400, Eddie EK block and a few other bits :p
http://www.overclock3d.net/thumb.php?id=2408
http://www.overclock3d.net/thumb.php?id=2411
nice worklog. Great quality work
Great fun reading this hope you do updates soon. I hope to learn to do some case moding myself starting with the little plastic side on the lanboy I FINALLY get to use now. Im so jealous of your TOOLS!!!
I call it (your case-) the bloktopus :) or blaktopus it's ALIVE!
Great work.
Great case!! Congratulations:up:
Hey thanks lads!
I've moved flat now so finally have the opportunity to get some more modding and tidying done to the case. I've got a few bits and bobs to buy that should perk the project up a bit.
Time to dust the dremel off again :D
Update finally!
Right update. Pics don't do this justice as it looks very nice in real life.
Not fiddled properley with the mobo yet but it installed Windows fine. The temps are a bit high on the CPU but I think I need to adjust the fixings a bit.
Added some drive bay stealthing and still lots more stuff to do like doing the floor in carbon fibre and some more black alu inside but it's looking good so far imo :)
New hole cut in mobo for cabling:
http://www.overclock3d.net/gfx/artic...091823248l.jpg
Dremeled that up as well as some more alu to cover the drive bays
http://www.overclock3d.net/gfx/artic...091824712l.jpg
http://www.overclock3d.net/gfx/artic...091825319l.jpg
There's a couple of scratche that I can polish out (this is my workhorse PC after all), but it's very nice shape apart from that, despite these terrible pics :p
Quick UV view:
http://www.overclock3d.net/gfx/artic...091825508l.jpg
http://www.overclock3d.net/gfx/artic...091826785l.jpg
http://www.overclock3d.net/gfx/artic...091826972l.jpg
Current hardware is:
Core2Duo E6600
DFI RD600 motherboard
2 x 1gb Mushkin HP2 6400
MSI 8800GTX 768mb
OCZ Gamextream 850w
Hitachi Deskstar 7K160
2 x Hitachi Deskstar 7K80's (in RAID 0, not installed yet)
Sound Blaster X-Fi fatal1ty edition with breakout
Crystalfontz LCD drive bay screen
Pioneer DVD-RW
Custom Water Cooling:
Swiftech Apogee CPU Block
Laing D5 Pump
Aquacomputers EVO 360 RAD
5 x 120mm SilenX High Performance fans
looks very nice. that side cover is so hawt
Aye it certainly helps keep the toasty ATI chipset less toasty (tho ~50°C load @ stock is rather a lot :eek:)
Some people wanted to see what the NB looked like before I cleaned it up:
I used plenty of tissues at first as there was so much, then some TIM and a clean cloth when it got to reasonable levels.
http://www.overclock3d.net/gfx/artic...192131886s.png
