yes. but don t know if it ll solve the problem for youQuote:
If you want to really make sure of the clear -- do this -- to the letter.
http://www.dfi-street.com/forum/show...4&postcount=24
make sure no conductant is between the smd chips
smd? you mean the capacitors?Quote:
Originally Posted by i found nemo
update to 406BTA and boot with 2.8v....
try also yellow slot... it works fine with my colddamnboot Utt..
currently using 406Quote:
Originally Posted by andre X_X
i am able to boot up the comp with 2 stick of ram on the orange and yellow slots fartest away from the CPU. but not able to boot up with 2 sticks when i use both orange or both yellow. any ideas? currently runing fine on stock speed without oc.
I wonder if you damaged the on die memory controller.
i dunno, but i know that i'm running fine with 2 sticks of ram on stock. with slots dimm1-2. works fine. but i can't boot up with 2 sticks on both orange or both yellow. so i don't think i damaged the die. btw i can't oc. if i do then i can't boot up on dimm1-2Quote:
Originally Posted by Eli
I have the same problem whit a xp4800x2 and did not do anything to it just booted one morning and id dident worked but have being running for over a year whit mine 2x1gig corsair but no longer have tryed it in 4 difrent boards but no luck the ram is working ok in oyher boards have tryed whit 5 difrent sticks of ram but no luck
Originally Posted by davidk21770
that doesn't work at all.
tested all bios too, no go
yesterday i swapped my opty to my 3700+ and it took 3-4 hours to finally boot with a blow on my freezer 64 pro, it irritated me...
