Originally Posted by jonnyGURU
They're ALL currently Wintech except for most X-Connects (1st Gen.) So I'd just say, unless you're in the EU and have an APFC X-Connect (because ALL APFC X-Connects are Wintech), just don't bother with the original X-Connect.
The X-Finity 500W is good for any 6x SLI or X1700 Crossfire.
The X2, same, and could probably do X1900 or 7x SLI. I actually had one running a pair of 7800GTX's (replaced it with the external SevenTeam 500W unit after I finished that review.) The problem is it crossloads under high 12V, low 3.3V/5V loads. So even though you don't exceed the 12V capability with a pair of 1900's, the 12V rail might still drop below 12V if you only have one hard drive, no PCI cards, no USB, etc. That's what happened to the X2 in the Legit Reviews review. The PC didn't crash or lock, but the 12V took a dive because of a load on the 3.3V/5V rail that was probably only around 20W.
The Aerocool ZeroDBA failed for the same reason, which kind of surprised me because Andyson actually knows what they're doing (independent regulation, et al.) But then again, the ZeroDBA 620W is based on one of Andyson's "budget" 550W units, was probably custom spec'd to meet a price point and then had a 620W label slapped on it by Aerocool. So go figure.
The 600W can handle even quad-SLI. We've bench tested it here with both OEM and retail cards and it passes with flying colors. But it still has crossload issues. I'd suggest a minimum 2A load on the 3.3V and 5V rails. Works fantastic with a RAID5 array. :D
These power supplies were all submitted and certified by nVidia and ATI. And they're certification is tough and it's not a "paid service" as some often imply. Since nVidia started the separate 7x list, I've resubmitted the 600W so it can get added to that list (nVidia didn't bother re-certifying PSU's that they had already certified.)
My big issue with Wintech is their old school engineering. They really can't do independent voltage regulation so they crossload easily. And the bigger the PSU, the worst the crossload. One thing that is good about them is their quality control. I will say that they are consistant.
