yes,use Tt before,fsb420 stable only,but now is 450Quote:
mch and fsb volts used ?
I've got them. I'm in England and have the Tuniq Tower 120 here. My Conroe is preordered. Should be here by 29th. I was #34 to order it!Quote:
Originally Posted by johnsally
@ Moonraker: Which MB r you going to use? P5WDH or BadAxe? ^^
I'm not using any of those. I've had such a bad history with ATI and I like NVidia so I'm already swain. I'm waiting for a Nforce 590 for Intel to come out. Possibly the DFI one that is on the back burner.
The layout of that one looks ace too -> http://img.hexus.net/v2/internationa...therboardB.jpg
Nice air clokcing as usual, coolaler. Keep pushing.
Thanks for the info...thats DEFINATELY a worthwhile upgrade!Quote:
Originally Posted by coolaler
K
Nice stuff as usual coolaler.
The TT Spirit is only 19db max, according to TT, so it should be really silent.
u r right,but who care?i don't care;)Quote:
Well, before you critize all those wr coolaler has done,
have you totally understand the architecher difference between AMD Dual core cpu and Intel Core duo cpu since Yonah released?
I don't think you do. If you feel that effort on the breaking
world record is boring, you should do some more research
how multitasking works between these two "totally different CPU"
Like I and Coolaler always discuss how to improve the result of any benchmark; but we compete each other.
At least you won't feel that's all boring but all the joyce.
I can just sit there and playing super pi all night long even on my birthday and not going to party;)
Thanks for showing the cooler Mr Coolaler, I ordered one.
Keep doing what your doing, I love it. It also helps OPB learn more.:D
your famous on overclockers.co.uk now!
Running two instances of superpi would slow down the times, because each instance couldn't use the whole 4mb cache. It is possible to run two, but you would never break a world record
