Originally Posted by Eastcoasthandle
Why do these "individuals" keep believing that you can buy a cheaper C2D and OC it to the more expensive ones and get the same performance? In the illustration that Sierra_Bound posted you can clearly see diminishing returns OC a E6300 to 3 GHz+ when Super PI is ran. Why can't people think? It's far better to get a higher clocked C2D (meaning paying a little more) then buy a cheaper one then get pissy when you can't OC the FSB 450 and up:slapass: :slapass: :slap:
To be honest you be lucky to get over 400 FSB in some cases. Most of you looking for a board that does 450+ FSB need to stop and think. Like most cars with a speedometer of 200+ doesn't mean you will achieve that level of performance. So, to know that a MB can actual produce a number of 450+ for the FSB in no way means you will achieve it for 24/7, stable operation. If you are trying to do it just to screen shot (w/o accurate, proper documentation of why you are posting it) just makes you a poser and gives false information about what that particular board and CPU can do under partical conditions. Some of you here are gamers anyway and, how pissed you will be when you system reboots everytime you load up CS:S. So lets be real about this. Most of you looking to oc your CPU to 450, etc need to just buy an E6700 or save your money until you can afford an X6800 and be happy for once in your life.
